Are Firebird and Camaro Mechanical Speedometers Interchangeable?
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey guys,
I am looking at swapping out my 85mph speedo for a larger 145mph speedo in my 84 TransAm. However, so far as I have been able to research, Pontiacs only came with mechanical 85mph speedos. Anything above that is electronic. I have found a 145 camaro mechanical speedometer for sale and was wondering if they are interchangeable? How do they fit if they are? Has anyone done this before? Any help would be appreciated, thanks!
Car: 1986 Camaro Z28
Engine: 400 chevy small block
Transmission: 5spd
Re: Are Firebird and Camaro Mechanical Speedometers Interchangeable?
I'm interested in the same thing, though I don't think it's just a simple swap...
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 1983 Daytona 500 Pace Car
Engine: CFI - 305
Transmission: Automatic-700R4
Car: 1984 Trans Am
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
They will interchange. I saw a pic of a 85 trans am cluster that had a working iroc speedo in the cluster. I have also seen camaros with trans am speedos. May not be direct drop in in terms of mounting but it would be damn easy to do.
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
On another note there was also another thread I posted in here a long time ago , turned out a guy with a 83ish bird used a 130mph speedo from a second gen.
theshackle
Mar 5, 2017 06:37 PM
Linson
Aug 21, 2015 02:12 PM
