Dakota Digital Gauges NEED HELP!
Old Apr 20, 2009 | 11:38 PM
Projekt IROC's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 5.7L V8
I have a set of Dakota Digital gauges and they have been working fine for the past month that i had the car. Recently the right half of the gauges have stopped working. Im not to tech savvy with these gauges and ive read the troubleshooting guide and im not too sure they cover my problem. Has anyone had this happen? Can anyone help?
The fuel, volts, and rpm gauges dont work.
http://www.dakotadigital.com/index.c...rod/prd168.htmName:  8025740119_248930561_IM1_09_565x421.jpg
Old Apr 21, 2009 | 10:11 PM
UDAMON's Avatar
Car: Mazda Protege5
Re: Dakota Digital Gauges NEED HELP!
did you do the install yourself? if not i would double check the wires back there and make sure its what it should be. id download the instructions from the link you provided and basically go though and reinstall them double checking everything. if there is a wiring diagram it should be pretty straight forward just take your time. good luck!
Old Apr 21, 2009 | 10:53 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
take out the gauges check the 12vred and black ground wires
and make sure the circuit board didnt crack from a bad bump in the road and killed half of the guages
but most likely 12v or ground wire
Old Apr 22, 2009 | 09:03 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
If they installed like mine, the only connection to the gauges is a ribbon cable to the cpu. I would check to see if it's completely seated where it plugs into the cpu.
Old Apr 26, 2009 | 12:26 AM
Engine: 350 5.7L V8
Thanks for all the help guys. It turns out that it wasnt getting the 12 volts that it needed. If i have any other problems ill be sure to ask you guys.
Old Apr 29, 2009 | 07:22 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Please tell me about your install, and any difficulties or challenges you faced in the process. I am looking to partake on this challenge soon and would love the upper hand if possible. Please post your thoughts and experiences.
Old Apr 30, 2009 | 01:19 AM
Al Hasse's Avatar
I had help with mine. Since my cluster wasn't stocked, I sent in a working set I acquired from a junkyard and Dakota Digital pretty much gutted the cluster and put in their own gauges. The cluster is connected via a ribbon cable (similar to computer hard drive cable) to a CPU that gets mounted somewhere under the dash. CPU receives all the inputs from your stock harness by tapping the signals from the original harness and runnnig another wire from there to the CPU.
The package comes with all the senders and adapters you should need. I already had electronic speedometer, so the VSS converter wasn't needed. For VSS on your 87, you may also want the SGI-5 box to convert the 8000 pulse per mile the sender puts out to something your ECM can read. http://www.dakotadigital.com/index.c...rod/prd126.htm
Instructions say not to run your speed signal close to the tach signal, but I (we) made that mistake anyway and had a speed indication while sitting still (inductive pick-up), that was soon corrected.
My car had 177,000 miles on it when I put them in, now it's at 235,000. You can request from them any odometer reading, otherwise they'll set it to zero.
Old May 1, 2009 | 05:44 PM
Car: 1987 IROC Z
Wow, what did they charge you for all of this on top of the cost of the gauges?
Can I see your setup ?
Where on the harness do you tap, right behind the dash or directly after the ECM ?
Thanks for the input Al !
Old May 1, 2009 | 10:29 PM
Al Hasse's Avatar
I had help with the install, did part myself as I work with electronics. We tapped the wires in the harness right behind the instrument cluster and ran them to the Dakota Digital CPU. It helps lots to have a wiring diagram for the car. I also used the original cluster (I sent in a different one to be retrofitted) to find which pin on the back went to what gauge/indicator.
Here's a shot I took while on the rollers at a dyno...
Old May 2, 2009 | 11:11 AM
Car: 1987 IROC Z
Do your turn signal indicators work ?
What did they charge you to send in the cluster and have them fit eveything into it ?
Old May 2, 2009 | 12:03 PM
Car: 1987 IROC Z
Does yours have a trip meter and odo ?
Old May 2, 2009 | 12:17 PM
Al Hasse's Avatar
Turn signal indicators are relocated to either side of the speed readout, high beam indicator is now to the right of the speed readout as well as a cruise "C" indication if you're equipped and hook that up. Had I known this prior, I might have filled in the openings for them and the other indicators across the top and repainted the bezel. The "BRAKE" and "SERVICE ENGINE SOON" indicators are now below the tach.
My 92 cost me about $950 when I got it, it's now $1100 on their site. Your 87 will be significantly less if you decide to go for it since they stock those and don't have to custom make them.
Old Jul 15, 2009 | 06:50 PM
Car: 1987 IROC Z
Well, its about that time. If you can believe it, I have a good friend who got tired of me fiddling with my stock gauges and bought me a set of the Dakota Digital gauges !!!
We will be beginning the install this weekend. Was hoping one of you might know where I can find the wiring diagram for the gauge cluster (87 TPI) . I know the gauge cluster itself is a wiring diagram in its 80's wackness, but an actual one would help.
Old Jul 16, 2009 | 04:42 PM
Car: 1987 IROC Z
..doh.. not finding the gauge cluster wiring diagram anywhere, not even on autozone's website. Where did you find the wiring diagram for yours ?
Old Jul 16, 2009 | 05:53 PM
Al Hasse's Avatar
You might find them at AllData, you may need to open an account. Great site for wiring and locations. The store that my stereo intaller works at has an account with them.
www.alldata.com
Lbibb
May 5, 2016 12:00 AM
rusty vango
Sep 29, 2015 02:44 PM
Gordonr1973
Sep 29, 2015 11:59 AM
Eric-86sc
Sep 28, 2015 11:37 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
