Digital guage swap
Old Apr 21, 2009 | 09:14 PM
johnrstuch's Avatar
Car: 89 Trans am GTA
Axle/Gears: not sure
Digital guage swap
what i want to know is,can i swap my analog guages in my car to digital,
and what is involved do i have to change the entire wire harness,or what
Old Apr 29, 2009 | 05:31 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Re: Digital guage swap
Its a big expensive hassle. I was going to buy a GTA with a broken digital cluster and just put in the regular cluster. You have to swap out the cluster, hook up manual AC controls (messed with those before), move the dash and everything to reroute some things, and rewire, and solder some other things. I eventually just passed because it was way more involved and expensive and parts aren't readily available.
Old May 7, 2009 | 02:08 PM
georgealtemus's Avatar
Car: 1987 gta trans am
Engine: 5.7l 350 supercharged and more
Transmission: 700r4 w/shift kit
Axle/Gears: moser 12 bolt w/373 aubern posi
You have to get all the body wireing,from headlight to taillight-digital cluster-push button ac/heater controll and motors for the ac/heater box.Or if you dont care about the systems monitor just splice into the analog wireing(the analog and digital clusters use the same senders)but youll still need the two digital cluster connections as they are differant.Either way its a bit envolved but it has already been done many times both ways.Check out other old posts on here.
Pilotrick50
Sep 2, 2015 12:48 PM
stickychinsac
Aug 31, 2015 06:06 AM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
355sbcTPI
Aug 19, 2015 04:38 PM
tartagliaz28
Aug 15, 2015 10:59 AM
