Help! Taking Off Auto Shift Knob
Old Apr 25, 2009 | 02:54 AM
morellimd's Avatar
Car: 83 Z28 Camaro+95 Pontiac Firebird
Engine: 305+3.4L V6
Transmission: 700 R4 w/ Shift Kit
Help! Taking Off Auto Shift ****
I am currently taking out the old carpet and plastics and replacing them with the new i have just bought. I am looking for advice on how to take the Automatic shift **** off the shift rod. The car is an 83 Z28 Camaro
Thanks , Rob
Old Apr 25, 2009 | 05:33 AM
84transamdude's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: Help! Taking Off Auto Shift ****
on the front of the shifter **** there should be a clip you just pull out and slide off the shifter
Old Apr 25, 2009 | 06:18 AM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
if you have the ball shifter ****, you have to pull the button up (the thing you push to get it out of park)
it will come out if you pull on it.
once the button is out, there is a circlip holding the ball on the metal shifter rod.
undo the circlip and the ball should come off just fine
to put it all back together, just reverse the process
Old Apr 25, 2009 | 10:28 AM
morellimd's Avatar
Engine: 305+3.4L V6
Thanks a lot! You wouldn't believe how many times Ive pulled on that SOB hanging out my T-Tops but i was seeing if you would know how to take out the center console as well?
Old Apr 25, 2009 | 11:43 AM
Car: 85 Camaro IROC
Engine: 5.7 TPI
for starters, the part that covers the shifter comes off with like 6 screws. there are 8 but two of them are fake and dont do anything.
after you get the top cover off, take the center console lid off, and there should be some more screws in the console box itself.
after that, good luck because thats all i know.
i think that it would be pretty easy, just undo every screw you see
Old Apr 27, 2009 | 11:17 AM
my82roc's Avatar
Car: 89 Iroc Convertible
There are 2 10mm bolts in the console box and 2 9/32 bolts on top of the console box.You also have to undo the radio and hvac controls from their mounts.Take off the ebrake handle and the brke lever must be pulled up as far as you can get it to be able to remove the upper portion of the console.the lower portion should be self explanitory but there are 2 bolts at the front one on each side that attach to the dash which are not seen
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
