Console not lining up anymore
Old May 1, 2009 | 10:38 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
I've noticed lately that my console is "sliding" toward the passenger side. This is resulting in it not lining up perfectly with the radio pod, causing the plate around the radio and heater controls to pop off, and looks bad. Anyone have any idea what the cause of this is?
Old May 9, 2009 | 02:43 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Console not lining up anymore
If you remove the shift plate and look directly behind the shifter, you will see a bar attached to the console bolted to the shifter(autos) or to a bracket on the trans hump(manuals)
This controls left/right alignment. Chances are, yours is loose
The above bracket coupled with the glovebox bolts control front/rear alignment
Some alignment will come from the lower stud on the radio pod which commonly comes loose(or breaks) in 3rd gens
Old May 11, 2009 | 09:29 PM
duey_roc's Avatar
Car: 87 Pontiac Trans Am GTA
Engine: 5.7 350 V8
Transmission: Automatic
Axle/Gears: ???
Mine is doing something a little different. the rubber rim around the center console itselfis popping out. How do i fix that?
Bubbajones_ya
Jul 6, 2024 08:32 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
chuck13
Interior Parts Wanted
Sep 22, 2015 11:19 AM
88HARDTOPIROCZ
Sep 18, 2015 10:30 PM
TBRays98
Sep 6, 2015 05:05 PM
