Door Panel Interchangibility
Old May 12, 2009 | 03:25 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Can someone tell me if the 89-92 door panels will fit on my 86 camaro.... ive been looking at the pics on 1A Auto and they seem a bit different... please let me know asap please yall...
power locks, power windows, manual mirrors
Old May 12, 2009 | 04:11 PM
Stephen's Avatar
Car: 87 GTA
Re: Door Panel Interchangibility
The basic panels will swap fine, between all Firebirds & Camaros.
The only issues you'll run into are power mirrors/power windows/power locks & such.....wiring in the door.....GTA arm rests vs all the other arm rests.....Stuff like that.
With a little work, I've seen 4th gen door panels put in, but those might only line up good with a 4th gen dash. Not sure about that.
Old May 12, 2009 | 04:12 PM
strc09's Avatar
Car: 1988 Pontiac Firebird Trans AM GTA
Engine: Tune-port Injected 6.3L
Transmission: Borg-Warner T56 six-speed
Axle/Gears: Borg/Warner 9-bolt with 3.70:1
I don't see why they wouldn't. I've heard of folks swapping between Firebird and Camaro door panels. I imagine they all bolt up the same way.
Old May 13, 2009 | 02:56 PM
1Aauto's Avatar
Former Sponsor
Hey Cory,
If you need help with color samples or questions feel free to call.
T
Old May 14, 2009 | 08:09 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
All 82-92 Camaro door panels are the same. Also, the 82-86 Firebird door panels are interchangeable with the Camaro door panels. However, some of the '87-up Firebirds used a different door handle trim piece so the panels have different openings for the door handles. You can use those panels in a Camaro as well but you need make sure you get the right door handle trim pieces to match. You can even install the molded GTA style door panels but you have to get the armrest mounting brackets that are rivited to the door.
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
May 7, 2016 06:23 PM
tglennon11
Sep 23, 2015 05:30 PM
NiG
Sep 7, 2015 11:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
