hatch pull down motor wont close
Old May 19, 2009 | 08:04 PM
marine68's Avatar
Car: 89 IROC Z28
Engine: 5.7 L Edelbrock perf /holley 3310
Axle/Gears: BW 9 BOLT 3:27
my rear hatch wont close. does someone have a wiring diagram so i can fix it. also has someone converted this to old school mechanical lock . what parts do i need for that swap.
Old May 20, 2009 | 12:52 PM
Darrell's Avatar
Car: 1991 GTA
Engine: L98 350
Transmission: 4L60
Re: hatch pull down motor wont close
Is it dead or did you open the trunk when the battery wasn't connected? If you open the trunk with the battery disconnected you just have to trip the latch and the unit should come up and start working again.
Old May 20, 2009 | 01:04 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
I had in the part converted mine to manual due to a variety of issues. Drilled a couple holes in the sliding plates while I had someone outside the vehicle make sure the lid was flat and level and put in some bolts to hold everything in place. From there, I just removed the lower motor section (what was left of it at least; everything was destroyed by the previous owner).
First things first, Darrell brought up a good point about tripping the switch if the battery was disconnected. I had the same issue when I hooked a battery up recently to my car after it sat for 5+ years.
Old May 22, 2009 | 01:12 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
I like the pull down. THere is a reversal switch and a switch at the latch. The way it works is:
The hatch switch is closed.
The thing moves until it hits the reversal switch, then it stops.
There is a inline fuse under the ds dash close to the fuse box.
There is a relay in the rear
The motor and gear housing are vunerable to breaking.
Check to make sure the housing isn't broke.
check the fuse
check the latch switch,
check the relay
check the reversal switch
Old May 25, 2009 | 03:08 PM
89Camaro89MI's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
I'm really angry with how poorly GM constructed those things. Needless to say, I've been having trouble with mine.
I've got it locked in place right now by removing the motor and fitting a piece of steel between the slide assembly and the bottom main bolt. I would advise against drilling through the sliders! That's what the previous owner did to mine and I wanted to egg his house. Though he proceeded to torque off the heads of the screws he used.
I actually just wired mine up manually, which was not that difficult, and set some switches on the empty panel under the running lights / brights ****.
It worked for about a day before the CHEAP PLASTIC MOTOR MOUNT decentigrated into like a thousand pieces.
If you're going to just rig yours up that way, I'll send you my "custom" fitted steel shunt, and you can send me your motor mount.
I can get pics, if you want to do it yourself. It isnt hard.
Old May 25, 2009 | 03:25 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Wait a sec, can someone explain the "tripping the latch" part? About four months ago I had to stop driving my car because I had to reregister it and I had to scrounge up the money to get it, it took me two months, and as a result the battery was dead, I opened the hatch a few times while the battery was dead to retrieve things and now the hatch doesn't pull all the way closed. It just sits about an inch above the rest of the body, can I "Trip" a latch like you guys are saying? Or is there a problem with it that needs to be replaced?
Old May 26, 2009 | 09:00 AM
marine68's Avatar
Car: 89 IROC Z28
the car sat for years before i got it. the pull motor is in bad shape, so is the wiring. a schematic would help so i can troubleshoot the connections.
Old May 26, 2009 | 01:05 PM
Car: 1989 Camaro RS
Engine: 305 TBI
The latch has two electrical switch components in it. The first is a button right on top that is depressed when the hatch connector contacts the acceptor. The second is a reversing switch, which is much more difficult to find. It's right on top the motor, on the inside, just above the gear housing.
Tripping it would be if the catch, the acceptor, is all the way down, then the battery is disconnected, then the hatch is opened. When the hatch opens, the motor should send the catch up.
For you, it sounds like another problem, but it could be an easy fix if your motor still operates and triggers when the hatch is opened or closed. Something simple like a piece of debris is the slider. All you have to do is remove that back plastic and have a look.
If you're still stumped, take off the plastic and snap a pic. Either me or someone else on these boards can give you the info you need.
Old May 26, 2009 | 01:12 PM
Car: 1989 Camaro RS
Engine: 305 TBI
I guess Autozone used to have wiring diagrams on their websites, but they arent there anymore. I looked everywhere for one, to no avail. Haines manual doesnt have one either.
This is what led me to wire it up manually, as noted above. But if all your motor components and things are structurally sound, It's worth it to fix the electrical components.
Old May 26, 2009 | 01:25 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
hope this helps. the pages cover opening and closing.
File Type: pdf
Old May 27, 2009 | 05:29 PM
marine68's Avatar
Car: 89 IROC Z28
thanks for the wiring diagram. i connected the wires by color and now the motor runs. i need to order new plastic slides for the motor tracks.
Old May 27, 2009 | 08:40 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Thanks for the tip guys, I messed with the little latch on the car and while I was driving home today it kicked in!
It works again! thanks alot.
Old Jun 25, 2009 | 11:00 AM
3rdGenDrifter's Avatar
From: I'm from hawaii, but I've been going to school in Grand Forks, ND for four years now
Car: 1989 Camaro, 1991 Firebird
Engine: 305 in the chevy, 350 in the bird
kkingsrulee: Happy to hear you got your hatch working
WISH I COULD SAY THE SAME FOR MINE!
to anyone out there: I replaced my rear hatch assembly and motor, wired it all up correctly only to discover that my switch in the console isn't connected to anything. The ONLY loose plug i could find under there is a three wire plug (black, green with white stripe and an orange). But this does NOT mate with the switch which has just two L-Shaped brass prong contacts.
here is what i need to know... does that loose three wire plug even go to the rear hatch? IF so, is there meant to be some sort of additional adapter plug to make it love the switch in the console??? Otherwise- what am I should I be looking for??
Any help would be appreciated! thanks
Old Jun 25, 2009 | 11:08 AM
FireChicken2.8's Avatar
Car: 1989 Red T-Top Firebird, 1989 Iroc
Engine: 2.8L 173 C.I., 355
Transmission: Th700r4 Auto, Built TH700R4
Hey, if you had a little more information that would help us help you. Does it do anything? Does the motor run but not move? You say someone converted it, does that mean the motor isn't even there? If it IS there, check to see if you have power to the motor. And start attempting to diagnose what is wrong exactly. Top Down Solutions, a TGO member, has all kinds of repair parts for the hatch motors and the prices are more than reasonable and the customer service is top notch. They also sell complete rebuilt pulldown motors if you want to go that route! Hope this helps!
Old Jun 25, 2009 | 11:11 AM
Sorry for my post, it wasn't showing there were any responses to your topic. Now I see there are.
Old Jan 4, 2011 | 07:31 PM
doorslammer69's Avatar
Car: 1989 IROC-Z
Transmission: 700-R4
Axle/Gears: 2.77
Thanks for the diagram.
Old Nov 7, 2011 | 05:21 PM
reefland's Avatar
Car: 1991 Camaro Z28
Engine: 5.7L
Bumping an old thread looking for some help from those who seem to be able to.
When I hook the red-white together and ground the black wires from the hatch motor harness, the motor goes all the way down. If I shut the hatch and then open it with the key, it just pops open, no lift up. The only way I can get the hatch motor to go up is the remove the relay attached to the unit and wire the motor directly.
I do not have the compartment light for the black-orange wire to connect to but this shouldn't stop the motor from going up, right?
Old Nov 8, 2011 | 08:23 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
That would be one of the switches or the relay. The light shouldn't matter. When the unit cranks down it toggles a switch to reverse the direction. If this switch isn't working it will go to one end and then stop. The other item is the latch switch that "senses" when the latch is closed to engage the motor.
Use the diagram above to trace the wiring and test the switches.
Old Dec 22, 2011 | 12:28 AM
AggieIROC13's Avatar
which fuse is this? I can't find it and I am sure mine tripped a fuse
Old Dec 22, 2011 | 08:03 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
The fuse isn't in the fuse box, there should be an inline fuse near the fuse box that should be it.
Old Dec 22, 2011 | 12:18 PM
is it a normal fuse? the only normal fuses i see outside the fuse box are for the viper alarm system
Old Dec 22, 2011 | 01:12 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
yes its just a spade fuse not a buss. This is true on some but not all the models what type of car do you have? I believe the holder is black.
Old Dec 22, 2011 | 10:49 PM
I have a 1990 IROC hardtop. 5.7 auto. I would appreciate if someone could post a picture? All I can find is the fuses for the alarm and the fuse box. does the fuse control anything else? so I can see if it is the fuse or a different problem. thanks!
Old Dec 22, 2011 | 11:23 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Correct only for Firebird. Incorrect info for Camaro.
On a Firebird the hatch fuse is 15 amps and is in a single fuse holder that is attached to the outside of the fuse block. It can be removed from the fuse block, since the fuse holder has a channel that slips onto a dovetal molded into the outside of th fuse block, so if you can't find it attached look for it near the fuse block.
On a Camaro the hatch fuse is called the LID fuse in the fuse block. It again is a 15 amp.
Before you go looking for a blown fuse, remove the hatch surround trim panel and test that you have power at the red/white stripe wire that plugs into the blue wire.
Lon
Old Dec 23, 2011 | 09:26 AM
ok thanks, the fuse is not blown.... so I guess I can check and see if I am getting any power? the light in the back does not seem to work anymore either
Old Dec 23, 2011 | 11:06 AM
mrrman's Avatar
may have the same issue with my latch motor...still checking this out
Old Dec 23, 2011 | 02:14 PM
am muscl's Avatar
Car: 86 Z28
Engine: 67 327cu. dart II heads
Transmission: 700R4 2200 stall
Axle/Gears: 3.73 gears
on mine the plastic gears are stripped is there anywhere that i can get a new gear. chevy says they are discontinued
Old Dec 23, 2011 | 03:24 PM
mrrman's Avatar
Its is this one?
http://www.ebay.com/itm/380388487197...84.m1423.l2649
Old Dec 24, 2011 | 02:23 PM
am muscl's Avatar
Car: 86 Z28
thanks i just ordered it
Old Dec 25, 2011 | 12:13 PM
hey, I was looking at the circuit layout file and I was wondering, if my light is broken, will my hatch not work? it seems to have power go to the light then from there to the hatch motor assembly. if the light does not work, will I not get power?
Old Dec 26, 2011 | 12:28 AM
lonsal's Avatar
The hatch light is powerd on a different circuit than the hatch pull-down unit.
FYI, the gear nut, along with every other item to repair these hatch pull-down units is available from my web site, and for a bit less than that eBay ad.
http://www.top-downsolutions.com/hat...ull-down-units
Old Dec 26, 2011 | 12:52 AM
Awesome-X's Avatar
Car: 87 Camaro
hey thanks lon you're the man!
Old Mar 15, 2012 | 11:38 AM
FireballXL5's Avatar
Car: 1988 FORMULA
Transmission: 4spd auto
Axle/Gears: standard
My latch is up and open, the lid when placed down wont close the latch, the fuse is good 88 formula
Old Mar 15, 2012 | 08:06 PM
lonsal's Avatar
Which fuse did you check? The fuse for the hach pull-down unit is not in the fuse panel, but is (or should be) in a single fuse holder that is attached to a bayonet shaped tab on the outside of the fuse holder. It would have been better to say you uunplugged the red/white stripe wire from the blue wire and confirmed that you have +12v there. Did you try re-setting the pull-down unit by pressing on the striker-sensing switch? It is a small black plastic paddle just in front of the latch assy. If that is no effect and you confirm the power is OK. Then either the striker-sensing switch or the reverrsing switch is in need of replacement.
Lon
Old Mar 15, 2012 | 08:44 PM
Car: 1988 FORMULA
Lon
The fuse is just on the outside of the fuse box, I looked at that when my horn wsnt working but will try this.
Old Mar 17, 2012 | 11:37 PM
Car: 1988 FORMULA
Lon
I tried that paddle, and nothing happened, the latch is in the dwn position with the clasp the the hatch latch open, shoulldn't that be in the up position replaced the relay that is by the motor, and still nothing.
Old Mar 18, 2012 | 02:00 AM
lonsal's Avatar
...Then either the striker-sensing switch or the reversing switch is in need of replacement.
Lon
Old Jul 11, 2012 | 03:43 PM
Jimmy64D's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 2.77
Lon, could you post a photo of the striker switch. Also, can you use a 12v battery to see if the motor is the issue?
Old Jul 12, 2012 | 12:11 AM
lonsal's Avatar
http://www.top-downsolutions.com/hat...h-pull-down-un
Lon
Old Nov 22, 2012 | 10:59 PM
my89camaro's Avatar
Car: 1989 Iroc-z camaro
Engine: 305ci HO
Transmission: manual 5speed
Axle/Gears: Borg Warner w/ 3.08 gears
i dont know if this helps you but i have an 89 camaro and i looked to see what color wires i have that go to the hatch switch. mine has 4 wires that go to an adapter(orange, dark blue or possibly black, yellow, and brown) after they come out of the adapter they split two different ways. brown and yellow wires connect to the switch. the other 2 wires go to an in console relay. i also forgot there is another black wire which appears to be just a ground. it sounds like a lot but looking at it in person its easy to figure out. hope it was some help
Old Jun 17, 2015 | 10:37 AM
supergraphic's Avatar
Excellent information guys. Waytogo on the selling of the
Reconditioned Striker Sensing Switch, 88-91 Hatch Pull-Down Unit
I'll probably be buying both components asap. Tired of fiddling with my stupid hatch closer.
Can someone show me how to wire up the dash mounted hatch release? I have all the parts from a junkyard but my car didn't come with the remote release in the dash.
Thanks!
Old Jul 4, 2015 | 02:41 PM
  #42
grandpajohnson's Avatar
How do you trip the latch?
Old Jul 5, 2015 | 09:37 AM
  #43
lonsal's Avatar
By "trip the latch" he means press on the striker sensing switch that I show 3 posts prior to yours. Press the switch down, the motor should activate. Continue to hold the switch down until you hear a CLICK which is the reversing switch being tripped to turn off the motor and end the down cycle. Release the striker switch and the motor should come on and power the unit all the way up until you again hear the CLICK of the reversing switch ending the up cycle.
Lon Salgren
Old Jul 27, 2015 | 03:47 AM
  #44
Paco131405's Avatar
Can i get pics of your latch?
Old Aug 2, 2015 | 11:07 AM
  #45
Car: 1989 Camaro RS
Engine: 305 TBI
Whoa! Talk about a blast from the past! That post was from 2009. Sorry to say my Camaro only lasted another year before my girlfriend decided to tangle with a Suzuki, and I never did get a good solution figured out.
From memory... I had basically removed the little motor and used it's mounting bolt location to shunt in a small piece of 16ga. steel I had drilled and bent to fit, holding the sliders just under top of slider travel. It... worked. Technically. But the seal wasn't very good. It did latch and lock, which was enough for me at the time.
Hope this helps.
Old Sep 12, 2015 | 09:27 AM
  #46
Master18's Avatar
Re: hatch pull down motor stopped working
Hey Guys. Quick question. My Hatchback pull down assembly has been working perfectly since i bought the car a couple months back. But just a couple week ago I noticed that when i went to close the the trunk it wouldn't catch. The unit was all the way down and just stopped working. Took whole unit apart and noticed that nylon sheaths were broken/in rough shape and just took the time to clean it all up a bit and do the best i can to re lubricate and check all the wiring's. could this be a motor problem? or a fuse issue and if its a fuse issue where is the fuse located exactly? thank you for any help on this. P.s. In the cab the release switch still works with clicking sound release but that's it.
Old Sep 12, 2015 | 09:16 PM
  #47
lonsal's Avatar
Nope, most likely is a problem with either the reversing switch or striker-sensing switch. Either can cause the symptom you describe. Of course the first thing to check is that you still have power at the red/white stripe wire that is plugged into the blue wire.
Lon Salgren
Old Sep 15, 2015 | 09:26 AM
  #48
Master18's Avatar
Thank you very much for input. Will check out. Where exaxctly is the striker switch and reversing switch located?. Believe i have an idea but just double checking. Thanks again
Old Sep 15, 2015 | 10:38 AM
  #49
lonsal's Avatar
Striker sensing switch attaches to the latch area with a single 9/32" hex head screw. There were two versions of the switch. The 86-87 had a large white pluf on the blue wire that plugs into the red/white wire. The 87-91 has a smaller black plug on the blue wire. That is the only difference, so if you find you need one you can easily swap the plug to the correct one you need for your car.
The reversing switch is monted on top of the plastic motor housing and connects to the two contacts on the motor.
http://www.top-downsolutions.com/hat...-pull-down-uni
I usually have both switches in stock if it turns out you need a switch. Both of these switches were only used on the 86-91 Camaro or Firebird. No other models share the parts. Cadillacs and other high-end GM autos used some of the same parts for their trunk pull-down unit (gear nut, wave washer, bearing, motor, motor housing), but they used a different reversing switch.
Lon
Old Dec 9, 2015 | 09:23 AM
  #50
gnilson's Avatar
Car: 1990 T/A
Engine: 5.0 TPI
Axle/Gears: 373 posi
Great info Lon,
I reset the latch switch and now it goes up and down but cannot be activated remotely. I am assuming my switch is bad, even plugged in another used one, still no go. Is there a way to tell with a multimeter if the switch is bad or not? Any suggestion on where to get a new switch?
TIA
Geoff
