getting door panel off n power window replaced
Old May 27, 2009 | 08:43 PM
IROCISBELL's Avatar
iam having a problem getting door panel off my 91 camaro.the top of panel is hard to get off and the rest of it is loose except top piece.any hidden clips? also has any one changed a window motor n have any special tricks?also any place to see exploded views of this? thanks everyone!
Old May 27, 2009 | 09:38 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: getting door panel off n power window replaced
Originally Posted by IROCISBELL
having problem getting door panel off.91 camaro.the top of panel is hard to get off are there any hidden clips?dont want to break top of hard plastic panel.got rest of it loose except top piece off.also any one changed a motor.any special tricks?any place to see exploded views of these. thanks
Welcome to the boards, the questions you ask have been covered in full detail many times. If you do a search by using the search feature here, all your questions will be answered and in some cases with pics. I'm not trying to be mean but searching is always a good thing. I know there are a few members here who will still answer your question even though they have answered it a hundred times, instead of waiting for a response, the search button does wonders.
Old May 27, 2009 | 10:22 PM
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
there are four clips on the hard plastic piece.
Old May 27, 2009 | 11:24 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Take hold of each end of the plastic piece and slide the entire panel forward.
It will slide off the clips and release!
Old May 28, 2009 | 12:33 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The official way is to pull the bottom of the door panel out to a 30*-45* angle. Then push the top plastic piece in towards the window opening. that should release the clips.
Old May 28, 2009 | 08:54 PM
IROCISBELL's Avatar
ok. thanks for the help everyone.i will try n see how that works for me.sorry i didnt search it was late n i was lazy.ha!
Old May 28, 2009 | 10:25 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
The reason I told you to search is because the project is harder than it seems. There are alot of posts here and some people seem to make the job easier than it is. You got some vauge directions with your replies, I have taken many door panels off and you just need pratice to get it right. If you live by any jy's go pratice on some junk ones and you will get it.
Good luck
Old May 29, 2009 | 10:01 AM
1Aauto's Avatar
Former Sponsor
Welcome to the forum.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
