just got some 4th gen seats
Old May 28, 2009 | 10:38 PM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
ok i have done a search buti just picked up a good pair of 4th gen seats and the driver is power i dont have power seats in mine but it looks like a grond and positive set upon two wires out of the new seat i just wanted to see what you all did who have done this thanks in advance
Old May 28, 2009 | 10:47 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
Re: just got some 4th gen seats
hook your ground to a ground, and hook your positive to an "always hot" fuse. your done. easy as that.
Old Jun 1, 2009 | 09:12 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
even though you don't have a power seat now, your car may very well have the harness for it tucked under the carpet. Take a look for it before you run a new line. The connector is different from 3rd gen to 4th gen... fortunately my 4th gen seat came with both sides of the connector and I soldered it in in place of the 3rd gen connector.
Old Jun 1, 2009 | 12:30 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Do yourself a favor and wire in a circuit breaker with your positive wire. They look like a fuse, but they are solid and silver. I think Im using a 20A...
But basically, if for some reason you try holding the switch in one spot too long, or something falls next to the seat jambing a switch active, it will blow the circuit breaker. Then..unlike a fuse...after awhile it will reset and your seat willw ork again. Without it there is a risk of messing up your seats power circuits or even melting a wire.
Its a VERY easy hook up.....
J.
Old Jun 1, 2009 | 01:10 PM
squeeezer's Avatar
Car: 5 cars
i too installed 4th gen seats into my 91
now ill have to peel up the carpet to see if i have a harness
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
cam-mike
Aug 24, 2015 07:23 AM
