Seat Track measurements
Old Jun 2, 2009 | 08:35 PM
tpi90rs's Avatar
Car: 87 Formula 350
Engine: 350tpi
Transmission: TH700R4
Axle/Gears: 3.23 limited
there's not a singe thread on this board with seat track measurements so I thought it needed one, and also because I need the measurements.
can anyone get them tonight? I just need front to back, and side to side.
and a picture of how the tracks are mounted to the seat if i'm lucky?
Old Jun 2, 2009 | 11:58 PM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: Seat Track measurements
You have to remove the seat to measure the tracks. There should only be two types of tracks, one for the manual seats and one for the power adjustable seats.
The seat and tracks attach to the floor pan by four 10 mm nuts, one at each corner. To access the nuts, you have to remove the trim cover.
The tracks, regardless of type, are attached to the seat with four bolts (the power seats also have "Adjuster To Seat Spacer", which seems to look like a spacer). One bolt is at each end of the track.
Dave
HP52TA
Feb 3, 2018 10:51 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
MORREALE5
Sep 13, 2015 09:01 PM
sandman92084
Sep 12, 2015 10:27 PM
MORREALE5
Sep 10, 2015 08:58 AM
