Help with my shifter knob button...
Old Jun 7, 2009 | 12:40 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Help with my shifter **** button...
Okay, so the button on my '83 shift **** is stuck down.
I removed the button, ****, and that long (6" long?), plastic, blue thingy out of the shifter tube. I cleaned, lubed and re-assembled it all, and the button is still in the stuck in position . Shouldn't there be some sort of spring or something in there?
What now?
Old Jun 7, 2009 | 04:51 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Re: Help with my shifter **** button...
Yes, there is a spring in the bottom of the assembly. I pulled one off the shelf and took a picture so you can see where it should be. The picture was taken from the front of the of the shifter.
Old Jun 7, 2009 | 05:06 PM
chazman's Avatar
Axle/Gears: BW 3.45
Maybe I'm having a hard time visualizing it, but that one looks different from mine.
I dug alittle deeper today..
The spring is broken and and the "J" shaped lockout thingy fell out of the shifter rod. I also found a "V" shaped clip sitting there. Not quite sure where the V shaped clip goes.
Old Jun 7, 2009 | 09:07 PM
chazman's Avatar
Axle/Gears: BW 3.45
Denny, if you wouldn't mind, could you shoot afew pics from different angles. I just can't figure out how this this goes back together.
Or if anyone has any pics or diagrams?
Old Jul 6, 2010 | 03:49 PM
19Chevrolet84's Avatar
Car: 1984 Berlinetta,'82 and '86 Camaro
Engine: Rebuilt 350
Transmission: Automatic. =[
Axle/Gears: Stock
Same problem, someone please help.
Night rider327
Feb 25, 2016 09:50 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
