What would you have to do... (Summit Digital Gauges)
Old Jun 18, 2009 | 02:46 AM
Camaero's Avatar
Car: 1987 IROC Z/28 Camaro
Engine: 355
Axle/Gears: 9 Bolt w/ 4.10s
How hard would it be to make the Summit digital gauges work in a 87 Camaro?
I'm looking at the following gauges for example:
http://summitracing.com/parts/SUM-G2984/
http://summitracing.com/parts/SUM-G2983/
http://summitracing.com/parts/SUM-G2985/
If they wouldn't plug directly in, what exactly would be required?
Thanks.
Old Jun 19, 2009 | 01:05 AM
Camaero's Avatar
Engine: 355
Re: What would you have to do... (Summit Digital Gauges)
bump...
Thanks guys
Old Jun 19, 2009 | 01:22 PM
madhatter's Avatar
Thanks.
the volt meter should be able to be wired without anything else. if you read the other to gauges, it say, "Notes Sending unit not included " which means you would probably need the sending units to, because the stock sending units may not send the right amount of ohms to the gauges which could throw off your signal giving you inaccurate gauges. with the sending units no problem, call summit they will know what you need.
Old Jun 19, 2009 | 01:27 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
Thanks.
click on the "suggested items" tab for the sending units on coolant & oil. volt gauge would tap into any 12v source when key is on.
Old Jun 19, 2009 | 06:55 PM
Camaero's Avatar
Engine: 355
Thanks guys! I appreciate it!
Bubbajones_ya
Jul 6, 2024 08:32 PM
69GTOby
Apr 18, 2016 02:34 PM
MantyZ28
Nov 8, 2015 06:54 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
86IROC112
Sep 11, 2015 04:04 PM
