Pillar Pod Mounting Hardware
Old Jun 18, 2009 | 07:43 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I just bought a 2 gauge pillar pod off Ebay for $40 shipped from a private seller.
After paying for this item, the seller tells me that it does not include the "mounting" hardware.
She says that she is selling it for her son and from what she can tell there appear to be holes in both ends which would leave me to believe all that is involved in mounting this is drilling a few screws?!
Can someone with one of these pods or who knows how they attach please shed some light on this? The seller has offered a full refund but if It's something as simple as just drilling a few holes than I don't think it would be worth the trouble to find another one. Although an extra measly $16 for a 3 gauge pod doesn't sound too bad either.
Do these things mount to the existing pillar using screws, do they replace the pillar using the factory clips or do they use their own proprietary mounting hardware? Thanks.
Old Jun 18, 2009 | 09:05 PM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
Re: Pillar Pod Mounting Hardware
they attach the same as our door panels do with the plastic push in panel clips but only smaller black ones
Old Jun 18, 2009 | 09:06 PM
chads89ta's Avatar
Engine: 305 tpi
Transmission: t-5
they attach the same as our door panels do with the plastic push in panel clips but only smaller black ones. but these go through the pod and into the pillar
Old Jun 25, 2009 | 01:21 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
the pillar pod goes on top of your existing a-pillar moulding just like a ...mold. You have to drill 4 or 6 holes (depending on your pillar pod) on your a-pillar. Like chad said, you can go to the autoparts or home improvement (Lowe's) store and get those little push clips. They look like plastic thumbtacks that have the little chirstmas tree pin and holds the pillar pod and pillar molding together... My autometer one came with them already but like I said, I've seen them at the autoparts and home improvement stores. Its nothing to worry about...
Bohemian
Aug 15, 2017 05:11 PM
Fox118
Sep 12, 2015 09:29 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
