Best Adhesive to Glue back Rubber to Plastic Interior Parts
Old Jun 19, 2009 | 05:00 PM
1985blktransam's Avatar
Car: 1985 Firebird Trans Am
Engine: 5.0 Liter Engine
Axle/Gears: 3.08
Hi:
1985 Trans Am with T-Tops. The Front window pillars on each side with The Plastic Trim covering up to the T-Top, the small rubber trim is peeling away from the Plastic Trim Piece.
What is the best Adhesive to use to Glue back Rubber to Plastic Trim ???
Any help would be gretly appreciated !!
Rob
Old Jun 19, 2009 | 08:50 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Best Adhesive to Glue back Rubber to Plastic Interior Parts
i use 3M emblem and trim adhesive. works really well for any plastic and rubber ive used. test a drop on whatever you are gluing to make sure it doesnt eat it.
Old Jun 20, 2009 | 08:20 AM
Axle/Gears: 3.08
Thanks for the reply, I will try it.
Rob
1992 Trans Am
May 10, 2023 07:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
