97 rear seats fit in a 3rd gen?
Re: 97 rear seats fit in a 3rd gen?
i just put some in mine. there is a bar on the center rear hump that i had to cut off. and i was not able to use the little leg covers from the third gen. i also need to order the seat belt holders since i bought dark seats.
Car: 1990
Axle/Gears: stock
you have to cut the bar in the back on the drive shatf hump or it will show through.
not a hard job, just need a cutting power grinder.
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
you only have to cut the bar IF you had an OEM split rear seat... If your back seat was 1 whole back piece from the factory (and not 2) then you should have no problems at all...
Car: 87 GTA
In my old 92, I swapped the OEM split rear for 4th gen single rear seat & never cut out the pivots in the middle. They weren't in they way either.
Car: 91 RS vert/ 89 iroc vert
Engine: 305 TBI/305 TPI
Transmission: 700r4Xtwo
Axle/Gears: 10 bolt non-pos. B/W 9 bolt pos
+1 my rears fit perfectly w/out cutting the "bar"welcome...
I'llrocya
Feb 2, 2016 11:43 PM
sailtexas186548
Jan 19, 2016 12:21 PM
sailtexas186548
Aug 26, 2015 03:32 PM
