Couple of racing seat/harness questions ?
Car: 06 Corolla
Engine: 1zz-FE 1.93L lol
Transmission: c59
Axle/Gears: fwd ftl
Ok so i have some black recaros i plan on installing in the z28 but i dont have any sliders for it, if i can bolt the stock sliders to the seats i will but has anyone purchased aftermarket sliders ? from where ? how do they work etc ?
and as for the harnesses the only place i have seen harnesses mounted is the hatch mounts behind the seats. is there a better place to mount them ? or should i just wait and mount them on harness mounts i'm gonna weld to the cage ? thanks for the input!
-brad
-brad
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Couple of racing seat/harness questions ?
I just made little bracket tabs to mount my Corbeaus to my stock sliders. works great.
Harness i ran over the 8pt roll bar and down to where the rear seats seat belt used to go.
Car: 06 Corolla
Transmission: c59
Axle/Gears: fwd ftl
cool thanks ill update when i pull the stockers and i will probably use the same mounting idea/hardware, you're talking about the place 'inside' the middle fold or w/e of the back seats correct ?
Car: 89 Iroc-z
Transmission: TH400
Yeah, i put the ends of my harness to those middle spots. You can go to the high side if you wanted to on both ends by the shock towers, as long as the harness goes over the roll bar's main cross beam for the loop, you'll be ok
