Why is my car leaking?
Old Jul 5, 2009 | 10:01 PM
5.0blackcamaro's Avatar
Car: '88 Camaro SC/Z28
Engine: 305tbi
my t-top camaro leaks a fair amount of water when it rains onto the edge of the rear seet right behind the frond seat, by the rear pillar, and i just had the t-top gaskets replaced, and the car alsow occasionally dumps water on my lap when i get on the brakes, which is coming from the drivers side t-top right where the t-top meets the windshield. Anyone got any ideas?
Old Jul 5, 2009 | 10:20 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Why is my car leaking?
I had to take mine back to the place that fixed the seals once or twice. I had a leak at the front just like the one you describe. The leak was actually at the front corner of the center bar, the water would enter at the corner, then run along the top of the windshield, then end up dripping on my leg. Really tough to find.
There is an adjustment for the tops behind the inner trim on the A and B pillars. If you remove the plastic trim, you can see the adjustment. You may also need to (or have it done) the windows adjusted to the seals. Most auto glass places can do that.
Old Jul 5, 2009 | 10:27 PM
Engine: 305tbi
thank you very much for your respnse, very helpful, as these leaks are indeed very difficuldt to find, thanks again for the help!
Old Jul 6, 2009 | 10:41 AM
50bmgshooter's Avatar
I just did my t-top weather stripping on my car and I forgot to seal the 4 corners were the weather stripping comes down from the t-tops to the window tracks. had 4 small leaks show up during the water test. put in a little bit of sealent in there and now no more leaks.
Old Jul 7, 2009 | 12:15 PM
1Aauto's Avatar
Former Sponsor
Yeah you need to 3M Adhesive these pretty good to seal them up.We carry the 3M Adhesive if any of you guys need some.
3M Weatherstrip Adhesive
Old Oct 22, 2009 | 08:32 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
any updates?
specialized
Jun 18, 2022 09:26 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
TheExaminer
Aug 26, 2015 04:59 PM
Exxon Limited
Aug 9, 2015 08:13 PM
drathaar907
Aug 6, 2015 04:20 PM
