removing the door panel in a 92
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
im trying to replace the door weather stripping on tmy 92 firebird, i can figure out how to take the coverplate off the door handle/lock area. It seems like there is a plug behind the door handle that is covering a screw, and the little square plate with the firebird on it seems to be covering one as well. How do you remove them? i dont want to break them or mar them all up and i having no luck. Am i missing something here? Its so much easier on the 86.
1 Post
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: removing the door panel in a 92
It's a real pain to get them off. There's one screw behind the square firebird thingy and one behind the black plug. You need to find something thin, blunt, and not metal. For the plug you just have to kinda pry it off. For the square bird you have to pry it out from the top. If you end up marring them 3rd gen ranch has them cheap.
Alex
Alex
Alex
Alex
1992 Trans Am
05-10-2023 07:19 PM
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
