side skirt removal
Old Jul 15, 2009 | 10:47 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
side skirt removal
Im trying to remove my side skirt on the drivers side, and i have gotten all the screws off the skirt except for the ones in front of the rear tire. i searched and saw that the screws are on the inside of the car and the inside pannel in the back needs to be removed. i cant seem to get that pannel off. do i need to remove the seat to get to screws holding that on?
also is that all the screws holding it on or am i missing some?
Old Jul 15, 2009 | 02:31 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: side skirt removal
You can access the screw through the rear speaker opening if you can get the speaker out and the insulation behind the speaker is missing. I have Bose so I don't have speaker baffling. To remove the baffling, you will have to remove or at least loosen the rear plastics. There is a screw under the seat back area. Using a small screwdriver or an angled driver, you can remove it without taking out the seats. This will allow you enough space to remove the speaker baffle. Reach in to the bootom and you'll feel the nut that needs to be removed.
Old Jul 16, 2009 | 12:02 AM
onesweet92z's Avatar
Car: 92 camaro z28
Engine: 355 tpi
Transmission: t-5
Axle/Gears: 373
on mine i just removd the black vent in the door jam and reached down in that way it tight but u dont have too mess with removing a bunch of parts
Old Jul 16, 2009 | 03:56 PM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
You can remove just the lower part of the interior panel!
Remove the lower seat cushion. You will find a screw for the lower section behind the seat (fold down the seat) . Remove the sill panel and the lower screw on the black trim behind the door window opening.
The lower half will come out, with a little finese.
A long extension and either a 7/16 or 12mm socket (deep well) works great!
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Wylecoyote08
Aug 22, 2015 01:58 AM
Street Lethal
Aug 14, 2015 08:25 PM
3rdgenparts
Aug 8, 2015 07:09 PM
3rdgenparts
Aug 5, 2015 11:57 PM
