Column Wobble at 7 o'clock
Old Aug 21, 2009 | 04:54 PM
RS90CAMARO's Avatar
My column moves back and fourth from center into the 7 o'clock position so I decided to fix it.I took my column apart today and found that the four bolts are tight but the pivot pins almost fell out. It looks like the aluminum housing is worn out. Has anyone ever replaced the housing or has a part number for it? I'm thinking of switching the column out but i cant find one with a airbag and vats. Could I switch an older column into mine and then bolt my airbag onto it? I have vats bypass so it doesnt matter if I get a column with it or not. Also will firebird columns fit into camaros? My car is a 1990 camaro V6 Auto.
Eric-86sc
Feb 25, 2016 09:02 PM
1992Z28!
Nov 19, 2015 07:33 AM
roysatikas
Sep 22, 2015 08:15 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Tweeks25
Sep 17, 2015 08:04 AM
