Is This Factory?
Old Aug 26, 2009 | 11:42 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Is This Factory?
I've always wondered. On my console in the little valley where the E-Brake rests, there is a small hole going through the console. It does not appear to be sloppily drilled so I was just wondering is this factory as it doesn't appear to serve any purpose.
Old Aug 26, 2009 | 11:44 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Is This Factory?
I would have to say no, no holes exist on any of the cars i've taken apart or owned.
Old Aug 29, 2009 | 12:33 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
can you post a picture? on my '84 TA there is a torx head screw under the e-brake that holds the console top to the base. not sure if this is the hole you're talking about.
Old Aug 31, 2009 | 11:12 PM
Car: 1985 Z28
It was nor factory. You can see on the backside where a drill went through.
The console is out cause I'm restoring the interior. So I just filled the hole with bondo before painting the console.
Wonder what the heck he used it for
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
