Back Seat Removal??
Old Aug 26, 2009 | 03:46 PM
jjohnston's Avatar
Car: 91 Camaro RS
Back Seat Removal??
I am trying to remove my back seats. I can't get them out. I can see a torx bolt in the side of the backs of the seats, but I've tried 3 different bits, and I can't find a way to get a torx bit to actuall fit in order to unscrew them...
Old Aug 26, 2009 | 04:03 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Back Seat Removal??
There is a nut on both bottom sides of the rear upper seats, look where the lap belt would be, and feel under the bottom corner of the seat, and you should feel a nut, that is similar to the nut that holds the front seats to the floor. Keep the seat in the upright position as you do this.
Hope that helps.
Old Aug 26, 2009 | 04:25 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Hope that helps.
and the bottom half has just one bolt in the front
Old Sep 25, 2009 | 12:33 PM
zapskate's Avatar
umm there are upside down bolts and ur ratchet has to be upside down mine came out in 5 minutes!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
lee01
Apr 9, 2016 01:56 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
3rdgenparts
Aug 8, 2015 07:09 PM
