88 iroc door panels diagonal divide or straight
Old Aug 27, 2009 | 07:24 PM
tomclayborn's Avatar
Car: 88 iroc vert undergoing resto
Engine: 5.0 tpi
Transmission: beefy 700r4 rdeglcltch vetserv t/go
Axle/Gears: g92 b/w
hey guys have an 88 iroc vert that i just orderd door panels for from 1a auto they sent me a message saying that they thought it wouldn't fit my car right now i have the set with the diagonal divide on them which i like better all of the diagonal sets i've see say for 89 -92 i'm sure they will fit am i missing something here is my car supposed to have the straight line panels in it? the diagonal panels will work right? my old ones did... if the straight panels fit 86-92 y wouldn't one from 89-92 fit an 88 just not be correct due to the style
diag line 89-92
http://www.1aauto.com/1A/Interior/Ch...P00051/1169195
straight line 86-92
http://www.1aauto.com/1A/Interior/Ch...P00024/1169188
Old Aug 31, 2009 | 03:39 PM
Engine: 5.0 tpi
Axle/Gears: g92 b/w
Re: 88 iroc door panels diagonal divide or straight
no comments on this guys
Old Aug 31, 2009 | 07:29 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Diagonal Schmiagonal - I would think either panel will fit the same - doors didn't change, so shape is the same - personal preference as to which style. The ONLY difference I saw was the third hole at the armrest, but since trhe armrest covers it anyway, who cares?
What about window crank holes - do they all come with them? I see the hole on one, not on the other, but it is black - It'd be nice to know abount since I have electric windows, and may need new panels soon.
Old Sep 1, 2009 | 11:29 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
All camaro panels from 1982 through 1992 will fit any camaro in that same range of years. The differences only lie in the styling. The straight line style may be 'period correct' for the earlier year'd camaros, and the diagonal ones may be 'period correct' for the later years, but, you could just as easily put a door panel from an 82 camaro on a 92, as you could put a 92 door panel on an 82. They'll fit, it just depends on your preference.
Old Sep 1, 2009 | 03:05 PM
1Aauto's Avatar
Former Sponsor
I can call the upholstery company if you would like,and check on that.just let me know.
Tony
Old Sep 1, 2009 | 03:32 PM
1Aauto's Avatar
Former Sponsor
I just got a reply back from the upholstery shop and was told,as far as they know that the amount of holes for the door pull were different.
The straight design had three near the bottom where the diagonal design has two.
I haven't messed around over here with any of these,so feel free to add to this if you guys have interchanged panels and what mods were needed to make the change.
Tony
Old Sep 1, 2009 | 09:16 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
I think the 89+ also have an extra metal bracket riveted or welded to the door. So if you put it on the straight style, you'll need that bracket or make one.
Old Sep 6, 2009 | 08:03 PM
Engine: 5.0 tpi
Axle/Gears: g92 b/w
thanks guys for all of the replies i am sure they will fit also i will confire about bracket when i find out thank tony
as far as the window crank holes i was told that it was a prefforated circle that could be popped out if needed
Old Sep 13, 2009 | 11:43 PM
91project's Avatar
Car: 1991 Camaro RS
Engine: 305 c.i. T.B.I.
Transmission: TH700R4
Axle/Gears: stock open 2.72
on another note, i'm making some custom door panels and i'm not sure what i should use as backing board
Old Sep 14, 2009 | 08:41 AM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
88-92 Camaro door panels used the same fabric pattern but any 82-92 door panel will fit.
Old Sep 14, 2009 | 08:53 AM
1Aauto's Avatar
Former Sponsor
You're welcome.Just relaying back what I was told be the manufacturer. Let us know how yah made out.
T
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
