window makes an annoying sound when rolling
Car: 86 bird
Engine: LG4
Transmission: A4
my window sounds like its a dying whale when i roll it up and down. i took the door panel off and sprayed some silicon spray on everything i could see but it still makes it ad its driving me crazy. is there something else i need to do to get the noise to stop?
Re: window makes an annoying sound when rolling
You can try to adjust the window,or put some white grease on the track.Not sure if the sweeps are dryed out and that's what's making the noise.
Just a few things to try and check.
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Yeah, Ide say some white grease. They sell it in a spray can, and it works wonders on squeaks, and such.
Car: 88 iroc vert undergoing resto
Engine: 5.0 tpi
Transmission: beefy 700r4 rdeglcltch vetserv t/go
Axle/Gears: g92 b/w
mine makes a loud whine noise because of the adjusters on the top of the door on the inside under the black top piece theres 2 of them on each side it seems like the fuzzy stuff is kinda wore off
Car: 86 bird
Engine: LG4
Transmission: A4
yea i looked at those fuzzy things also and mine are worn out some it might be a possibility and my window sweeps also
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
sorry to revive an old post, but my window is making that same screeching noise when it goes up and down. i was just wonering if the noise stopped when u replaced the felt pieces or if it was some other issue?
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
I got the same problem. Check out my issue
http://www.youtube.com/watch?v=xu-2gfG6i-U
1992 Trans Am
May 10, 2023 07:19 PM
theshackle
Sep 17, 2020 08:26 AM
