1987 trans am hatch latch help
Old Oct 16, 2009 | 04:43 AM
Spoolin Turbo's Avatar
i have a 1987 trans am i just bought it dose not have a hatch latch and im wondering if its the pull down motor type. now i though all 87's had the pull down motor type now i look at the wiring for it and it dose not have the wiring for it what do i do? also I'm not sure if the brackets are different for the non pull down motors or not witch iv heard they are, and if they are mine is the bracket for the pull down motor type
Old Oct 16, 2009 | 05:31 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Re: 1987 trans am hatch latch help
Yes, your '87 is supposed to have a hatch motor. The body brackets are different so you can't put a normal latch on it without welding in different brackets. The hatch motor wiring is part of the tail light harness so you can always get a new harness with the hatch motor wiring. However, it seems wierd that somebody would take out the wiring. (It wouldn't make much sense.) Are you should it's not just tucked behind one of the interior panels?
Old Oct 16, 2009 | 07:34 PM
Yes im pretty sure but ill make 100% sure. but the 3 rear most panels are ripped out and i look for about an hour and did not find a thing. so much for your help. EDIT: yes i just look and there is no sign of the wiring being there what would you suggest to be the easiest way to fix this?
beachrodder
Aug 25, 2015 08:05 AM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
g.l.mos
Aug 22, 2015 12:02 AM
Randomtask2
Aug 13, 2015 01:57 AM
z28addict8490
Aug 7, 2015 08:48 PM
