rear seat removal
Old Oct 18, 2009 | 10:31 AM
AndyMcG's Avatar
rear seat removal
Hi I was wondering if anyone would know how to remove the rear seats in a 90 camaro.
Old Oct 18, 2009 | 10:39 AM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Re: rear seat removal
Bottoms have a little screw in the front under the cushion you have to take out. The backs are attached by a screw on a bracket on the outside of each seat and have a rod that slides on the center part. Its like a 13 mm nut or something on a stud through that bracket. Basically where the seat back meets the bottom, in the back sort of underneath there is the bracket and nut.
Old Oct 18, 2009 | 10:53 AM
AndyMcG's Avatar
Awesome, thanx. Also found an article on Super Chevy that describes the same thing.
I found the torx (star) bolts on either side but wasn't sure how to get to them. I never thought to look under the bottom cushion.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
MORREALE5
Sep 13, 2015 09:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
z28addict8490
Aug 7, 2015 08:48 PM
