Looking to do a 4th gen interior swap
Old Oct 22, 2009 | 07:57 PM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
I have a 87 iroc-z and i am looking to swap for 4th gen interior.
wheres the easiest and cheapest places to gen part?
what all parts can i use from a 4th gen?
Old Oct 22, 2009 | 08:05 PM
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
Re: Looking to do a 4th gen interior swap
I know the seats bolt right in. I've seen pictures with the center console, radio, and HVAC panels too. Not sure how hard it is though.
Old Oct 22, 2009 | 08:17 PM
Njs305t/a's Avatar
Car: 1987 Trans Am
Axle/Gears: 2.73 posi
Do a . There's been many, many threads about this swap.
Old Oct 23, 2009 | 12:40 PM
hedberg667's Avatar
Car: 1989 GTA
Engine: 5.7 350
the search bar is your friend. The seats should bolt right up and the center console should go in with a little bit of fandangaling but the dash and the side panels require a little more work. The dash has the added complexity of wiring the gauges and other radio and HVAC controls. People have done the swap though and im sure a quick search will show you a step by step
Old Oct 25, 2009 | 09:17 AM
Transmetal's Avatar
Car: 89 Trans Am GTA
Engine: 5.7 350 TPI L98
Axle/Gears: Borg-Warner 3.27
I just picked up front black/charcoal cloth seats from a 99 Firebird in excellent condition for 60 bucks. Gotta love Craigslist.
Old Oct 27, 2009 | 06:48 PM
ShMaCk2004's Avatar
i got a whole 95 firebird interior (dash and all) for $250, gotta go pull it out on thursday. one quick question about the 4th gen dash tho. Does the upper dash pad come off with screws or is it clipped on? im not tryin to break it when i remove it.
any other pointers for removing that 4th gen interior are welcome and wanted.
Old Oct 28, 2009 | 05:42 AM
andrewmp6's Avatar
The parts ain't the problem its that nothing bolts right in all you have to make fit the car.
Old Oct 28, 2009 | 10:03 AM
ShMaCk2004's Avatar
thats not what i'm worried about, i just seem to have a problem with breaking things that clip on
Old Oct 28, 2009 | 03:21 PM
383isme's Avatar
im doing the same swap i have leather seats and door panels out of a 4th gen maro in great shape an im about to get a center console an dash out of a ta for free hopfully.. i herd you have to mate the 3rd gen pillers with the 4th gen with a little fiberglass and prolly shorten and maybe narrow the dash but im sure all this is in a step by step diy thread.. Good Luck with the swap!
Old Oct 31, 2009 | 12:40 AM
ShMaCk2004's Avatar
now im looking for help on the wiring. any good diagrams or anything?
Old Oct 31, 2009 | 01:42 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Again, "search" is your friend. There are thread with a pic of what 4th gen wires do what (good for pigtailing).
You might want to also get the a-pillars from a 4th gen as well.
IIRC the 4th gen dashes are about 1-2" shorter on each side when installed. One post there, the OP took 4th gen a pillars and trimed them to fit (took A LOT of work). Otherwise the dash will look incomplete. Ojne guy did do a custom dash out of fibreglass and it fit really well.
Also, you have/using AC? I've yet to read about a swap where the ac/fan controls work the same. Something about the fan speeds not working like they should.
Old Nov 1, 2009 | 07:59 PM
ShMaCk2004's Avatar
I found all the info about the instrument cluster and a-pillars, im looking for the headlight switch and a/c controls mostly. i only need the a/c controls to be able to turn the fans on and controll the speed. im fine with having no a/c and leaving the heater on defroster
Old Nov 3, 2009 | 01:59 AM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
I beg to differ on the AC panel swap part. I mated my thirdgen HVAC lines and vacuum lines to the 4th gen HVAC controls and everything works as should.
Old Nov 3, 2009 | 02:11 AM
ShMaCk2004's Avatar
how did you wire it? and wiring on the headlight switch would be helpful too
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
