will a 84 berlinetta digital dash work in my 85 z28
Car: 85 Z28 Camaro 2011 camaro LS
Engine: 350 Edelbrock Crate bored .60 over
Transmission: 400 turbo
i found a 84 berlinetta digital dash that was just rebuilt for a restoration now the owner is parting out his berlintta. i was wondering if it will work in my 85 z28 will it be plug and play or does it need modifications or is it not worth it to put it in
Re: will a 84 berlinetta digital dash work in my 85 z28
If you can get a wiring diagram for both years, you can compare them and see what's different. It's not hard to repin the harness to make it match with the other side of the harness.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
The entire dash and center console are physically different. The turn signals, wipers, steering column, HVAC etc. are completely different. I believe the wiring would be a nightmare unless you moved everything over. If the dash or any other specialty components fail, then you're stuck paying a premium price for replacements. Many times they also do not work.
true so i will probably just keep mine the way it is
The_Phoenix
Feb 4, 2016 07:10 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Sanjay
Aug 12, 2015 03:41 PM
beachrodder
Aug 7, 2015 04:27 PM
