Headliner repair tutorial (many pics)
Old Nov 13, 2011 | 11:52 PM
  #51
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Re: Headliner repair tutorial (many pics)
This thread really motivates me to tackle my headliner. I was originally planning to just pickup a ABS one but my backboard is perfect. Where are you guys getting the fabrics? Would be nice to get some samples before I tackle doing so and then just end up having a mismatched red interior.
Also about the headliner retainers. I busted one or two removing the headliner. Is this fixable? Meaning can I just get new ones and reattach it to the backboard? Would really suck doing all that and having to glue it back on.
Old Jan 8, 2012 | 07:50 PM
  #52
the blur's Avatar
How do you remove the A pillar trim without destroying it?
Old Jan 17, 2012 | 03:58 PM
  #53
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
you have to slide it back, towards the back of the car, then remove..
Old Jan 17, 2012 | 04:16 PM
  #54
mrrman's Avatar
I have to do mine in my 67 Firebird....thats a ways away and not sure if i will do it of have someone do it for me....great writeup
Old Jan 17, 2012 | 05:45 PM
  #55
82tarecaro's Avatar
67 Firebird is totally different. There is no backer board. There are bows that hold the plastic material up.
Old Jul 13, 2012 | 11:01 AM
  #56
1991_RS's Avatar
Car: 1989 Formula Firebird
Engine: Swapped 350 TPI speed density
Axle/Gears: 2.73 (soon to be 3.42)
Came across this after we did the liner on my 91 Camaro coupe. I didn't use any cloth because the resin permeated into the cardboard backer already. Biggest tip is to make sure to get all the old foam off the backer first. We glassed both sides and it was as stiff as, well, a board!
Bought headliner material from JoAnn's (black) and used the 3M spray to stick it down. We found it works best if you have a couple extra people to help hold the material over the board and lower it down onto it, patting it down, starting in the middle, working towards the outside edges.
Old Aug 17, 2012 | 10:11 PM
  #57
Eightyninef's Avatar
took my head liner, sail panels, sun visors to an interior shop. $140 later, looks better than new.
and I just reinstalled everything.
Old Aug 30, 2012 | 06:26 PM
  #58
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
http://2min.powerblocktv.com/interio...n-30&pr=single
Old Nov 9, 2013 | 01:45 AM
  #59
RocketyMan's Avatar
Car: '96 Camaro-Vsux -- SOLD, '84 Z/28
Engine: 3.8L, 305 SBC
Transmission: 4L60E, T-5
Axle/Gears: 3.08s, 3.23s
I know this thread is old but I wanted to subscribe and post part number of the nylon "A-pillar" or also called "garnish moulding clip rivet retainer fastener."
GM Garnish Moulding Clip 20462090
Old Nov 12, 2013 | 06:12 PM
  #60
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
Hi,
BlackDog36 you did a pretty decent job with your headliner.
I have been doing automotive upholstery for a full time living for over 5 years now
and part time for over 20 years after i attended WTI tech college for upholstery.
I would of used and do use a different adhesive.
I am not familiar with the adhesive you used,
but most in aersol cans do not hold up to the high temps
the inside of a vehilce can get during the summer months.
Technically, there is a different material for the sail panels.
But, I usually do not use it - the headliner material works just fine.
The material is not supposed to have the foam backing over the speakers.
BUt as i said, you did a pretty good job.
Nick McCardle
Sep 10, 2015 08:36 PM
Stryker412
Sep 7, 2015 09:11 AM
TheExaminer
Sep 6, 2015 11:40 PM
mrdevontay
Sep 2, 2015 08:04 PM
