My 4th gen dash swap
Old Nov 7, 2009 | 05:13 PM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
ok im working on my 4th gen dash swap and everything is in the car but i am having wiring issues with the headlight switch.
the problem is the the interior lights do not turn on, everything else works fine.
got them to work, it was a grounding issue
Old Nov 7, 2009 | 05:38 PM
ShMaCk2004's Avatar
Re: My 4th gen dash swap, help needed!
this is how its turning out.
Old Nov 8, 2009 | 02:28 AM
ShMaCk2004's Avatar
if it helps any the dash is out of a 95 firebird and the car its going into is a 87 camaro
i really need help with this quick, any wiring pinouts or just tellimg me what wires to hook up for the interior lights will work.
Old Nov 8, 2009 | 09:34 PM
ShMaCk2004's Avatar
nvm i got it done
SEM landue black is quite nice
Old Dec 29, 2009 | 06:02 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
nice! so what was the fix?
Old Dec 29, 2009 | 06:36 PM
oscarsrs's Avatar
Car: 91 RS/ QX56/Altima 3.5 SE
Transmission: AUTO
Axle/Gears: ?
Originally Posted by ShMaCk2004
nvm i got it done
Nice, but why the big gap on the side ? you can see thru it
Old Dec 29, 2009 | 09:04 PM
ShMaCk2004's Avatar
fix for what?
that gap was a peice missing from the console. i found one and put it on. I'll post pics later.
still need a 93-96 firebird dash pad tho
or just look at my cardomain http://www.cardomain.com/ride/2936729[
Old Dec 29, 2009 | 10:29 PM
mw66nova's Avatar
Engine: 7.0L
i'm doing this swap soon. i'm wondering if you could give me a schematic on the light switch and dimmer. this is the only function that i need to make work as i'm using autometer gauges, and NO HVAC system.
Old Dec 29, 2009 | 10:52 PM
ShMaCk2004's Avatar
its pretty strait forward.
HEADLIGHT SWITCH
Orange to orange
red to red
yellow to yellow
brown to brown
the brown also needs to go to your dimmer switch input and the output from that goes to the grey wires for your dash lights and also the grey lead for the headlight switch
DIMMER SWITCH
Outer Wires
Black - ground
White - Dome light
Inner Wires
use one for input and the other for output
Wire Funtions
white is for the dome lights
grey is dash lights
yellow to headlights
brown is your parking lights
the orange and red are hot at all times
all black are ground
CHECK ALL OF YOUR GROUNDS!!!!!!!!!!!!!!!!!
if something isn't clear tell me.
what dash are you using?
Old Dec 29, 2009 | 11:15 PM
fearsomeformy's Avatar
Car: 1991 Formula
Engine: 305 TBI....:/
Diggin' that! I didn't know that was possible. Looks great! I would love to do this someday. Thanks for the info.
Old Dec 29, 2009 | 11:26 PM
ShMaCk2004's Avatar
the whole swap wasn't that hard at all. all i really had to do to mount is was make 2 brackets for the bottom bar to bolt up to and trim the ducting a bit.
took the air bag out too
Old Dec 30, 2009 | 06:51 AM
mw66nova's Avatar
Engine: 7.0L
very nice. thanks for taking the time to run that down for me. i'm using a 98-02 'bird dash and console. i'm going to pickup the dash today, and hopefully get it in the car sometime next week.
Old Dec 30, 2009 | 01:46 PM
ShMaCk2004's Avatar
cool post up some pics when its done
if you need more help let me know
Old Jan 1, 2010 | 10:53 PM
mw66nova's Avatar
Engine: 7.0L
when you were putting the dash in, did you have to trim anything off the car, or off the dash for it to fit flush? or just kinda hold it in place while you sinched down the fasteners? mines not really sitting very flush against the firewall.
Old Jan 25, 2010 | 12:45 PM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
it looks great, im in the middle of this as well do you have the pinout for the gauges?? and do you know if i can just run them off the stock sensors? like oil press sensor, water temp, t56 speed and fuel sending unit which im sure i will need a resistor for?? i have a 02 trans am gauges and dash and its going in a 89 trans am carbd and t56
Old Jan 25, 2010 | 06:36 PM
ShMaCk2004's Avatar
I did have to trim the top or the brackets on both sides off the car and bend them in a little bit and make a bar for the bottom. after that the top on the firewall was completely flush (except on the driver side. had to make a piece to come off the firewall to hold it) Just have a buddy hold it up and put the pass side bolt in then you will have to drill 2 small holes in the firewall for the middle bolts to go into.
From what i have read on here is the 98-02 clusters do not work. You need a cluster from a 93-97. you dont need to change any sensors and your speedo should be right if using the t56. (mine is off ALOT with my t5)
I used these pinouts
Attached Thumbnails My 4th gen dash swap-95_ta_cluster_pinout.jpg   My 4th gen dash swap-wiring3rd.gif
Old Jan 26, 2010 | 03:51 AM
ShMaCk2004's Avatar
Finally got around to posting final pics (for now)
still need a dash pad 93-96 firebird dash pad if anyones got 1
i have a temp on there now that kinda sticks up a lil bit but its better than a hole.
also the shifter boot is on now as well
Old Jan 26, 2010 | 07:51 AM
thanks for the info and your dash turned out great. Good job.
Old Jan 26, 2010 | 03:37 PM
ShMaCk2004's Avatar
thanks dude, if you have any more question let me know
Old Feb 21, 2010 | 11:46 AM
Draon's Avatar
Car: 1984 Camaro
Engine: 305 4bbl
Axle/Gears: stock :(
hopefully you can help me out. i'd like to embark on this swap, but don't know if i will run into problems since my engine is only a 305 4bbl. hope ya can help me out
preston
Old Feb 21, 2010 | 06:21 PM
ShMaCk2004's Avatar
I really don't see how what engine you have will make much difference at all. The 305 4bbl is what my car had in it from the factory but that was replaced with a 350 a long time ago. Now im moving to an LS1 so let the re-wiring begin
Old Feb 24, 2010 | 10:34 AM
Draon's Avatar
Car: 1984 Camaro
Engine: 305 4bbl
gonna start the dash swap today, anyone care to tell me how long it will take?
Old Jul 3, 2010 | 11:36 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
HEADLIGHT SWITCH
Orange to orange
red to red
yellow to yellow
brown to brown
DIMMER SWITCH
Outer Wires
Black - ground
White - Dome light
Inner Wires
Wire Funtions
grey is dash lights
Can you possibly elaborate on this a little bit for me?
Are all of the wires needed to hook up the fourth gen headlight switch found in the connector that plugs into the third gen headlight switch? What exactly does the brown wire for the headlights hook into, besides the other brown wire?
(I know this thread is a little old, but worth a try. )
Old Jul 6, 2010 | 12:25 AM
Draon's Avatar
Car: 1984 Camaro
Engine: 305 4bbl
i believe there are 2 wires that don't get connected, but i'm not 100% sure (i'm not at my car right now). and if they were it would be from the 4th gen connector. as for the brown wire, no idea what it exactly hooks up to, but hey when it works then who cares in the end. just make sure you got all the right schimatics for your car and the 4th gen, colors of wires tend change sometimes. hope that helped some. if by anychance you come across an extra 4th gen dash pad let me know. i'm out here in hawaii, and the one junkyard i've found has no f-bodies in it worth a ****.
Old Jul 6, 2010 | 12:37 AM
Thanks for the reply man.
I actually buttoned up the wiring last night and had to make my own tweaks. Your right about some of the wires not being the correct colors, but I made my own chart to reference as I modded my harness and it worked out pretty nicely. I dont remember exactly what I did with the headlight switch, all I know is that I got it working, lol. Except now my high-beams arent working, but I dont really care, as I never use them anyway.
Good luck in the Dashpad hunt.
Old Nov 7, 2010 | 05:42 PM
92redhotcamaro's Avatar
So I'm figuring i will do this swap this winter while my car is off the road. I have a 92 camaro. I found that most all dashes will work but not always with the cluster gauges. There are 93-96 camaro dashes. 97-02 camaro dashes. And 93-02 firebird dashes. If i leave my gauges what dash would be best to use or are they all the same? And if i decide to swap my guages what guages bolt in with what dashes and will still work in my camaro? Basically I'm wondering what will be the easiest way to go .
Jorlain
Aug 24, 2022 05:11 PM
Casey Meyers
Mar 2, 2016 10:46 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
sreZ28
Aug 14, 2015 07:48 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
