'82 dash compatible to the one found in the '89?
Car: 91 RS vert/ 89 iroc vert
Engine: 305 TBI/305 TPI
Transmission: 700r4Xtwo
Axle/Gears: 10 bolt non-pos. B/W 9 bolt pos
visually they seem similar but is there any differences.
i need a dash for my '89 and i may get a good deal if not free from an '82
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: '82 compatible to the one found in the '89?
I'm guessing you're thinking about the interior? The interior is compatible? If so, then for the most part yes. The dashes themselves might not be, but the center console, , carpet, seats, panels, will swap...
i apologize, i did not read the post before it was submitted
edit......DASH!!
edit......DASH!!
Re: '82 dash compatible to the one found in the '89?
ok thanks
i guess the guages off my 89 will also bolt on right
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
You will need to pull the gauges, speedo, and tach ( Anything that you want to use ) from the 89 cluster and install them into your 82 cluster.
The 1989 clusters printed circuit is not completely compatable with the 1982-1984 dash harness. If you try to simply plug the 89 cluster into the 84 dash than you will have problems with the backlighting as well as the BRAKE warning light. ( look where the BRAKE light is located on Each cluster ! )
Car: 89 Iroc Convertible
Ghettobird52
Jul 5, 2024 11:18 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
