grant steering wheel installation problems.
Old Nov 24, 2009 | 01:34 PM
Duke!'s Avatar
I'm wanting to put in a grant custom steering wheel on my 92 camaro
how do I remove the stock steering wheel?
what tools do I need?
Old Nov 24, 2009 | 01:40 PM
bakes85's Avatar
Car: 1985 trans am
Engine: 1969 chevy 350 .060 over
Transmission: 5spd
Re: grant steering wheel installation problems.
does the car have an airbag?
Old Nov 24, 2009 | 01:44 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
you need to remove the steering wheel over thing (airbag). You have to access the bolts on the back of the steering wheel. I don't remember if they are phillips screws or torx screws. Reach behind the wheel and you'll feel the holes (since they are facing the gauge cluster). After you take those screws off, you'll be able to remove the air bag and the horn button assembly. Once you've done that, you should be able to see the hub where the wheel attaches to the steering column. You'll need a steering wheel puller to remove the old wheel. Once you've popped it out, put the grant hub on and bolt it down and then bolt the grant steering wheel to the hub...
Old Nov 24, 2009 | 02:16 PM
Duke!'s Avatar
thanks for the information.
and yes it's a stock 92 rs camaro so it does have an airbag.
Old Nov 25, 2009 | 11:39 AM
HCR13's Avatar
Car: 1987 Trans Am
let us know if you need more help!
Old Dec 2, 2009 | 09:24 PM
mtflyboy's Avatar
Car: 1991 Z28
i was doing this and didnt know about the wheel puller ahhaa so thats why it wouldnt come off...
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
