weak lock motors...help
Old Dec 4, 2009 | 04:17 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
i got a keyless entry system put in over the week and i have to click the lock button a couple times for my lock to lock all the way..the motor is weak im guessing so could i just spray some WD-40 inside of the gears or should i replace the whole thing?
thanks
mikey
Old Dec 4, 2009 | 05:46 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: weak lock motors...help
thanks
mikey
Common problem. Clean with WD-40 and relube with white grease. While you're inside the door panel, consider the following link:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Old Dec 4, 2009 | 07:37 PM
one92rs's Avatar
Car: SOLD!!!!!
JamesC
wow thnks james for the search giveme. i was just looking for that post since i will be doing door handles tomorrow. damn little springs.
Old Dec 4, 2009 | 08:06 PM
U.S.Marine09's Avatar
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
i had the same problem and all i did was take the door panel off and spray everything with wd-40 and they havent failed i sprayed my window motor to and that worked better idk if its my imagination or not but hey guess i made out
Old Dec 5, 2009 | 08:10 PM
RaTcheTmasTer's Avatar
Be sure to do as JamesC says . . . loosen them up with WD-40 but spray them with white lithium grease or spray after you work them some. WD works good to free things up but is not a good long term lube.
Old Dec 6, 2009 | 08:14 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
okay thanks james =]
guide to take off the dorr panels?? aha
Old Dec 6, 2009 | 09:05 PM
mikespeed's Avatar
Car: 87 IROC
https://www.thirdgen.org/forums/inte...ock-issue.html
I just went through the same thing. The door panels come off much easer than I thought. One thing I will add, I didn’t get ALL of the moving parts on the inside of one of the doors, so take your time. Looks like I'm going to have to go back in. Another thing I didn’t think of until after I was done was to lube the inside of the locks, where the key goes. Once I did that I almost crapped my pants. Before, it felt like the key was going to break; now it turns with almost no effort. I also got myself a door panel popper tool, ( http://www.sourcingmap.com/pieces-noscratch-car-door-panel-trim-removal-tool-audio-refit-set-p-30471.html ) it made getting the door panels off a synch. Once it was al said and done, I'm sorry I didn’t do it sooner.
Old Dec 7, 2009 | 04:17 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
thanks everyone =] will report back when i do this
(prolly today at shop class)
Old Dec 11, 2009 | 08:42 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
check that your relay is grounded good behind the driver side kick panel. they used a self tapping screw to ground the relay to the body and it works itself loose over time.
Old May 31, 2011 | 03:29 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Resurecting this thread.
I tried spraying lubricant as mentioned and nothing. Other than a nice and clean looking mechanism. Ended up buying new AC/Declo motors from Classic Industries. Took a couple of hours on the first (learning curve) and the passenger door took all of half an hour. Hooked everything up and replaced the door panels and other hardware.
It worked!!! Ever since 1993 my locks were tempermental. Now they work as they should have from the factory.
Old May 31, 2011 | 05:35 PM
one92rs's Avatar
Car: SOLD!!!!!
I tried spraying lubricant as mentioned and nothing. Other than a nice and clean looking mechanism. Ended up buying new AC/Declo motors from Classic Industries. Took a couble of hours on the first (learning curve) and the passenger door took all of half an hour. Hooked everything up and replaced the door panels and other hardware.
do you have the part numbers for the ac delco motors.
Old May 31, 2011 | 06:42 PM
MY87LT's Avatar
Car: 1987 Camaro LT
I threw the boxes away. I'll post the numbers tonight after I dig them out.
Old Jun 1, 2011 | 05:08 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
I had the same problem
1A auto sells a great door lock actuator
http://www.1aauto.com/1A/DoorLockAct...01/309317/1982
http://www.1aauto.com/1A/DoorLockAct...03/304479/1982
Old Jun 1, 2011 | 10:47 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Well the boxes were picked up already and I was too late. They were original AC/Delco ordred from classic industries. But i'm sure aftermarket will work fine as well. Don't forget to transfer the brackets from the old units to the new ones.
Old Jun 18, 2011 | 10:56 AM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
great info. thanks for posting.
Kory
Falcon50
Aug 22, 2020 03:26 PM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
lanceflame44
Sep 25, 2015 12:28 PM
