Heater A/C control light melted
Old Dec 16, 2009 | 08:08 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
I removed the heater controls and see that the upper right hand side of the control is melted. I look below and there is the light blub that goes into the control to light it is on the ground with a melted housing. The light still works though.
is it normal for these to melt? Also will a 92 firebird heater a/c control unit fit a 92camaro?
and also is there anyway to unclip the wire that holds the light bulb pigtail or do I have to cut and splice to get another pig tail on there?
Old Dec 16, 2009 | 08:37 AM
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
Re: Heater A/C control light melted
No it should not melt. You might want to make sure that the bulb is the correct size. You're probably going to have to splice in a new pigtail.
Old Dec 16, 2009 | 10:33 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
Thanks for the reply. Does anyone know if the firebird heater controls fits the camaro. it looks like it might have an extra light but im not sure.
Old Dec 16, 2009 | 11:21 AM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
It has a few extra lightbulbs and it requires a little bit of work to fit but many people have switched over because it looks much better. If you do a search I'm pretty sure there is a thread or tech article that goes over how to change it.
Alex
Old Dec 16, 2009 | 08:22 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If you don't find an electrical issue that caused this melting, you might want to consider an LED replacement, since they draw so little and practically no heat emitted.
Frozer!!!
Jan 19, 2024 04:55 PM
The_Phoenix
Feb 4, 2016 07:10 AM
lakeffect2
Aug 23, 2015 08:44 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
