Seat Belt Guide fix
Old Dec 18, 2009 | 07:29 PM
MuhThugga's Avatar
Car: 2005 GTO
Engine: LS2
Axle/Gears: 3.73 LSD
Seat Belt Guide fix
I recently had to repair my cousin's seatbelt guides in his 88 GTA. The plastic piece that the screws thread into fell out and the guides were just hanging there.
Rather than take the entire headrest apart to try and get everything sorted, I just got some press-in drywall anchors and pressed them into the holes. Then screwed the guides into the anchors. Holds very well.
Just thought I'd share that simple fix for everyone who doesn't want to disassemble their entire headrest.
Old Dec 18, 2009 | 07:52 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
Re: Seat Belt Guide fix
they don't stick out?
I don't have that problem with mine...mine are cracked. If I get new ones, how will the seatbelt go through? remove from where it mounts?
Old Dec 18, 2009 | 08:21 PM
Drew's Avatar
When you buy replacements for your 92 from the dealership, they're split in the middle so you can slide them onto your existing belts, and they have an adapter that goes between the guide and the headrest.
Old Dec 18, 2009 | 09:29 PM
MuhThugga's Avatar
Car: 2005 GTO
Engine: LS2
No, they don't stick out.
Old Dec 18, 2009 | 11:52 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
That's a great idea!
BTW,I've seen different styles, not sure if they're all original though. Some have a couple of offset screws that allow the seat belt to pass through before the second screw is attached while others do not.
Old Feb 18, 2010 | 03:39 AM
chupachups12's Avatar
This is a good idea. I might try this quick fix on my seat belt when needed. Thanks
Old Jul 15, 2012 | 12:09 AM
SkyKitt's Avatar
Car: 1988 Trans AM GTA
Transmission: 700r4 with shift kit
Axle/Gears: Stock
I am going to try this since it seams hard to get those half moon metal clips in and I lost one of them. I also came up with an idea, to stop the seat belts from sliding out of the guide by using a 1" long piece of fuel hose and since mine are black it is hard to notice. You could also use clear hose. I will send a pic later.
Old Jul 15, 2012 | 10:31 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I've done that!!!works very good.
Old Jul 17, 2012 | 06:02 PM
MuhThugga's Avatar
Car: 2005 GTO
Engine: LS2
I'm just going to update and say that these are still working as well as they did almost 3 years ago now.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Amillionoh7
Sep 5, 2015 11:44 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
mrdevontay
Sep 2, 2015 08:04 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
