Fiberglass interior good idea or bad idea
Old Dec 21, 2009 | 11:14 PM
T1m3_Sh1ft3r's Avatar
Car: 1986 Trans Am
Transmission: TH700R4
Axle/Gears: IDK yet
I hope that i didnt fail at searching, but what i was thinking since im wanting to change the color of the interior of my car to make a fiberglass panels and hope that it would be cheaper than going to Hawks(nothing against them) or would i be spending as much as i would buying from hawks. i kinda wanted to get it so it would match the exterior paint that i would be painting. im not afraid of hard work, but i dont want to end up with 600 in the hole when i could have bought it for 250. the paint i would end up using probably be the same paint as i used on the exterior.
if any of you guys have suggestions im all ears, im just trying to make my bird stand out a bit
Old Jan 15, 2010 | 10:23 AM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
Re: Fiberglass interior good idea or bad idea
doing fiberglass yourself isnt really that hard or expensive.....u can buy most materials at an auto parts store.. just take your time and use your head and u'll be fine.
Old Jan 15, 2010 | 11:13 AM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
couldn't you just use a plastic primer of some sort and just spray the plastic you have? there are guys on here that have changed color on interior with paint/primer for plastic but not sure if they used reg body paint.
or are you going with something custom?
Old Jan 15, 2010 | 05:52 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
so you want to make a totally custom interior out of fiberglass? good luck. Look into the plastic dyes to recolor the interior or get new panels. Making panels to replace the interior ones will take a lot of time and work. Probably spend a few hundred on just the fiberglass and other supplies to make the parts, and then you still have to mold them somehow.
Old Jan 20, 2010 | 01:44 AM
Car: 1986 Trans Am
Axle/Gears: IDK yet
well i thought about going and doing something custom, but i think that it might require a higher skill set than what i have, i would use a dye but i have heard that they don't last very long, or maybe it was the plastic paint, i know i used some plastic pain before and the paint has stared to peal, but that may have been because i didn't so something right. i would love to goto a junkyard but im noticing that most of the yards here dont have the color interior that im looking for, i would goto hawks but i dont think that they have all the pieces im looking for, and i have a hard time justifying 250 + shipping for something like that if i could make it. So in other words if anybody you know that has a complete black interior for a firebird and looking to sell im buyin ;D
Old Jan 21, 2010 | 02:44 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
What black parts do you need? I have a lot of black interior pieces, I could load 'em all up in the back of my truck and meet you somewhere...
They're from a Camaro, but I think most parts are the same, aside from the dash.
I'm only 20-30 miles away from you, on the other side of the hood canal bridge.
Frozer!!!
Jan 19, 2024 04:55 PM
86IROC112
Apr 9, 2016 10:20 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
Reddeath210
Oct 6, 2015 08:20 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
