Shift Knob Help
Old Dec 24, 2009 | 01:51 AM
marekdennhardt's Avatar
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Shift **** Help
Which shift ***** will screw on directly.. or is compatible with the '85 V6 stock 5 speed tranny?
Old Jan 2, 2010 | 08:50 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Re: Shift **** Help
bump
Old Jan 6, 2010 | 11:01 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Re: Shift **** Help
If anyone wants to know, I picked up a **** from an old Fiero that looks like it will fit. Ill post when I find out
Old Jan 14, 2010 | 06:23 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Shift **** Help
There really aren't that many aftermarket ***** that will fit unless you're looking to spend big $$$ on just a shift ****. When I first did my swap, I had an APC ****/pedal set I used because I didn't have a brake pedal pad... I had to take the pad off of the clutch pedal as well, and even then, they kept falling off, no matter how tight I made them. They were thrown out a long time ago.
As for the shift ****, I thought the directions were simple... Slip it over the end of the lever, tighten the set screws and center the ****, and go. It DIDN'T fit! I had to screw the thing DIRECTLY onto the shift lever! And even then I only got about a half inch of the thing on there, leaving the lever about 2" too long... That got replaced with a $5 stock shift **** I bought from someone on here...
Old Jan 14, 2010 | 07:03 PM
Stephen's Avatar
Car: 87 GTA
Re: Shift **** Help
Years ago, I took a pool ball, drilled it out & threaded it. Easy new shift ball. Easy on a manual tranny, since there it no lock-out button like on an automatic.
Old Jan 17, 2010 | 01:31 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Re: Shift **** Help
Well if anyone ever searches this thread up for help with a shift ****, I found one that fits. It's from a fiero. It screwed right on. Direct fit. The one I got was in rough shape but ill attatch a picture of it.
Old Nov 7, 2011 | 12:44 PM
cha_chard's Avatar
Car: 89 Camaro RS
Engine: 2.8L V6 MPFI
Transmission: 5Speed
Re: Shift **** Help
what size drill bit and tap did you use?
Night rider327
Feb 25, 2016 09:50 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
