Need Help ASAP
Old Jan 7, 2010 | 12:41 AM
82_Z28_Camaro's Avatar
Car: 1982 Z28 Camaro
Engine: 5.7L 350
Transmission: TH350
Need Help ASAP
What do I do?
I attached a picture, if you look closely you can see that in my shifter a piece of metal broke in half, it's the piece at the bottom on the picture. Its stuck in drive right now, any suggestions?
Old Jan 7, 2010 | 03:55 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Need Help ASAP
Cant really see it at all in the pic but best bet is to get a new stock shifter as I bet that one is toast for sure
Old Jan 7, 2010 | 09:48 AM
Engine: 5.7L 350
Transmission: TH350
Re: Need Help ASAP
yeah i figured lol, what do you think about a b&m shifter? it would replace the part that broke, worth it?
Old Jan 7, 2010 | 01:58 PM
6SIX6's Avatar
Car: 89 IROC
Re: Need Help ASAP
Do you have a shift kit in your tranny?? From what I remember if you do you can get the full feel of shifting it manually if not all you can do is use it like your stock one and just put it in drive. If you are just going to drive it like its a stock one i suggest to leave it the way it is but thats up to you. Save the coin and put it into something else for the car.
Old Jan 7, 2010 | 02:08 PM
Engine: 5.7L 350
Transmission: TH350
Re: Need Help ASAP
im weighing all options right now, i would rather not spend the money on the b&m lol im pretty sure that i can shift it back into park from under the tranny
Old Jan 7, 2010 | 02:12 PM
6SIX6's Avatar
Car: 89 IROC
Re: Need Help ASAP
You could do that or just shove a couple of pieces of 4X4's or bricks under the tires as that works as well but like i said its up to you saves you time goin unde the car.
Old Jan 7, 2010 | 02:21 PM
Engine: 5.7L 350
Transmission: TH350
Re: Need Help ASAP
yeah im gonna see if i cant get a replacement part because im pretty sure that im not the only person who has broken this
Old Jan 7, 2010 | 02:34 PM
6SIX6's Avatar
Car: 89 IROC
Re: Need Help ASAP
Either that as those parts might be haqrd to come by or hit a wrecker for a used one as I dont think it would cost you more than $10 for it. If I had my old one I would have sent it to you if you wanted it.
Old Jan 7, 2010 | 03:09 PM
Engine: 5.7L 350
Transmission: TH350
Re: Need Help ASAP
yeah theres a junk yard a few miles away with an 88 iroc, ill have to check it out tomorrow
Old Jan 7, 2010 | 03:58 PM
6SIX6's Avatar
Car: 89 IROC
Re: Need Help ASAP
hey its only 4 bolts and a couple c-clips and its out and cheaper in the long run as well
Old Jan 7, 2010 | 04:09 PM
Engine: 5.7L 350
Transmission: TH350
Re: Need Help ASAP
ya the shifter is like $200
Old Feb 16, 2010 | 06:34 PM
89rser's Avatar
Re: Need Help ASAP
looks like it broke before and some idiot tryed to weld it back together from the broken edges......i mean having it tack welded would probably work, but it would have to have a plate either over or under the original break to work well at all....
92GTA
Apr 9, 2016 07:39 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Brother Al
Oct 14, 2015 06:39 AM
92projectcamaro
Sep 24, 2015 08:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
