just a quick 4th gen gauge cluster question
Old Jan 24, 2010 | 05:47 PM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
i bought a 2002 trans am ws6 dashboard with gauges. are these computer controlled gagues or could i use them on my carb'd setup with the t56, basically just run off the sensors???? i am not worried about all those warning lights just the gauges. I was gonna go and buy autometer gauges but if i can wire those in i would prefer that.
and if so does anyone have a diagram or pinout for a 02 ws6 gauges?
Old Jan 25, 2010 | 09:49 PM
Re: just a quick 4th gen gauge cluster question
ok so from the little info i was able to get i think i wont be able to use this gauges and will have to get some 97 trans am gauges could someone verify this for me please
Old Mar 10, 2010 | 04:48 PM
kroc84's Avatar
Car: 1984 Camaro SC - K-RocZ Custom
Engine: 355 SBC
Axle/Gears: 3.45
im in your same situation what did you ever come up with?
Old Mar 10, 2010 | 05:14 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
The 02 uses a serial data wire to control the gauges. This is why people use the earlier gauges becuase they have separate wires to the sensors. I believe 98 was the last year before going to serial data.
Old Mar 10, 2010 | 05:19 PM
kroc84's Avatar
Engine: 355 SBC
Axle/Gears: 3.45
Ok thanks I have a 97 cluster that im gonna use, i have a 85 camaro with a carbed 355 with a 700r4 trans I assume im goin to have to get this vss module i keep reading about right?
Old Mar 10, 2010 | 06:01 PM
i ended up getting a 97 trans am gauge cluster and swapped out the cover piece from the 02 just because it looks better imo
Old Mar 10, 2010 | 06:04 PM
kroc84's Avatar
Engine: 355 SBC
Axle/Gears: 3.45
so did what did you do about the tach n speedo, did you need that vss module?
I'm running a carbed setup with a 700r4 and im confused obviously lol
Old Mar 10, 2010 | 08:17 PM
i have a carbed engine and a t56 i think the tach signal is just like any other tach and you can run it off the msd ignition box if you have one or the negative on the coil? idk. and the speedo you can just come out of the speed sensor but on a 700r4 you might need some sort of converter box.
Please do not quote me on this since i have not done any of this yet and my car is still in pieces. I am no where close to installing the gauges yet.
Old Mar 10, 2010 | 08:29 PM
kroc84's Avatar
Engine: 355 SBC
Axle/Gears: 3.45
cool thanks for your help
Old Mar 10, 2010 | 10:17 PM
1981LT1's Avatar
Engine: LT1; LT1
many of the aftermarket electric speedos will take the vss signal and convert it correctly after your program the speedo. For the mechanical versions, you may have to play with the gearing in the tail housing to get it right.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
redmaroz
Aug 16, 2015 11:40 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
