installing umi sfc's. need to remove carpet first?
Old Feb 3, 2010 | 12:38 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
im in the process of installing dynamat and b-quiet sound deadener. over everything. floor,trunk, walls,doors etc...
but im concerned i need to wait.
i plan on having umi subframe connectors welded and installed whenever winter is over here in connecticut. which could be 2months from now
ive heard that some people had to remove their carpet because of the welding heat to avoid burning/fire.
---but my question is.... do i need to wait on putting dynamat in the front where the driver/passengers feet go until the subframes are in?
i only ask because id like to finish one project before moving to the next but also i dont wana keep my car in pieces while waiting for subframes.
but doing it the right way is usually the best way to go
Old Feb 3, 2010 | 02:59 PM
pearl_iroc's Avatar
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
Re: installing umi sfc's. need to remove carpet first?
I'm planning something similar and I'm gonna wait till the sub frames are in before I put in the dyno mat, just in case, especially since dyno mat uses a rubber side to adhere to the car
Old Feb 3, 2010 | 03:45 PM
H8TRAFIC's Avatar
I was advised to pull my carpet back when my SFC's were installed. I'm glad I did cuz the floor was pretty hot. You may want to wait on the dynamat till the weldings done.
Old Feb 3, 2010 | 03:50 PM
Stephen's Avatar
Car: 87 GTA
Definitely install/weld (even the bolt-on SFCs should be welded in place) the SFCs, before installing any Dynamat, insulation, carpet or anything.
Welding can very well burn up what you had just put in. Light the carpet on fire & there goes the whole car!
Old Feb 4, 2010 | 09:10 AM
Bobby_80s's Avatar
Axle/Gears: no idea
ok thanks guys, ive already did half the car in dynamat but just the rear seats to the trunk. i'll wait on the firewall/ front floor area until the welding is done.
thanks for your input.
i just was curious because i wondered what people do when they did dynamat and decided after the fact or yrs later or next owner decides to do SFC's ya know.
Old Feb 7, 2010 | 10:41 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
the guy welding could also not weld the connector all at one shot if he welds alittle at a time it'll create less heat and not burn the floor when i did my connectors i had the dnyomat installed and it actually helped it cause it burned to the floor for better adhesion since you have to use a heat gun to apply it
no green
Jan 9, 2016 09:22 PM
1992Z28!
Nov 19, 2015 07:33 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Briandrex
Oct 5, 2015 06:20 AM
roysatikas
Sep 22, 2015 08:15 PM
