speedometer needle jumps by 5 mph back and forth!!!!!
Car: 1983 z28 camaro
Engine: h.o. 305
Axle/Gears: posi
1983 z28 camaro.
i have a factory gauge cluster with a 165 mph speedometer. as soon as the needle leaves zero it rises like it should but it bounces up and down with a range of about 5mph. what could it be and how do i fix it?
thanks
thanks
Re: speedometer needle jumps by 5 mph back and forth!!!!!
Probably got a sticking speedo cable. You can probably just pull it out and lube it up as long as the sleeve isn't kinked, burned, or otherwise damaged.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I didn't read JamesC's link, but I had the same problem with mine. I removed the whole cable and lubed it Graphite lube.
No problems since. cost a few bucks.
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
The 85 mph cluster in my sport coupe had the same problem I replaced the speedo cable but still did it. Turned out it was the actual speedo head itself. It's probably just the cable but the head might be bad as well.
Good luck
Alex
Good luck
Alex
Now, gentlemen, would I leave the possibilities mentioned above out of my link
JamesC
?JamesC
ambainb
Apr 25, 2016 09:21 PM
db057
Aug 11, 2015 10:11 PM
