4th gen sunvisors
Old Feb 3, 2010 | 12:49 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
4th gen sunvisors
I assume they would work, but I wasn't sure. 3rd gen sunvisors are getting hard to find and used ones are a gamble. Plus 4th gens are a little bigger. Just curious.
Old Feb 3, 2010 | 12:59 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 4th gen sunvisors
Just curious too: Why a gamble?
JamesC
Old Feb 3, 2010 | 01:05 PM
Car: 1994 Trans Am
If they are used, its only a matter of time before they break and become loose and fly off because of a bump in the road. Thats why I don't have a driver sunvisor in my car.
Old Feb 3, 2010 | 02:08 PM
JamesC's Avatar
The hanger and/or sleeve is the usual culprit--but fixable:
https://www.thirdgen.org/forums/inte...un-visors.html
JamesC
Old Feb 3, 2010 | 02:26 PM
Drew's Avatar
Thirdgen sunvisors are easy enough to recover too. They're like the headliner, only a thousand times easier. The hard part is restitching around the edge.
One solution I don't see in the thread JamesC linked to...
If the pin rotates, 9 times out of 10 you can tap the pin back into the housing with a hammer. The elbow is cast, and then the pin is pressed in. Overtime the splines on the pin can strip the elbow or vibrate loose. A couple taps with a hammer will push the splines deeper into the elbow and embed the splines. It doesn't always work, but it's really fast and easy when it does.
Old Feb 4, 2010 | 11:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I have a 4th gen, and I can tell you the 4th gen visors suck worse than any I've ever seen - they are half as thick, very very flimsy, and my Bud Light box has sturdier cardboard than the 4th gen visors (they are literally just very thin cardboard). Stick to 3rd gen visors, and refinish them.
Old Feb 26, 2010 | 02:51 AM
chrisblazzer89's Avatar
Car: 1986 Camaro
Engine: 350 v8
Axle/Gears: 10 bolt,disks, 3.23 posi rear
would any other vehicles have sunvisors that would be an upgrade from stock ones on our cars?
my86bird
Oct 23, 2015 12:20 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
cam-mike
Aug 24, 2015 07:23 AM
