For Those With Floppy Sun Visors
Old Jul 7, 2007 | 06:00 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The floppy visor syndrome is common to our cars. The problem lies in the hanger, not the visor itself. Note the silver "bullet-shaped" piece below. If that piece has broken free and rotates in its housing (the black piece), visor flop will occur. Fix? Some members have used JB Weld; some have drilled through the housing and visor insert (the silver piece) and used a roll pin. Perhaps the easiest fix is a trip to the bone yard. I bought a pair for two bucks. Other fixes are welcome.
JamesC
Old Jul 7, 2007 | 09:30 AM
Stephen's Avatar
Car: 87 GTA
Re: For Those With Floppy Sun Visors
Hmmm....I like the roll pin idea. 20 years from now, they will still be holding, rather than new ones wearing out again.
Mine mostly hold, but on bigger dips and bumps, they droop. Or if I put my CD holder on them, the extra weight makes it droop, just through regular driving, nut just dips and bumps.
Old Jul 7, 2007 | 03:05 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I use velcro to keep them up. Even with the top down they stay put.
Two cents.
Old Jul 7, 2007 | 04:20 PM
JamesC's Avatar
The use of Velcro eventually aided in dragging down the headliner in my coupe.
JamesC
Old Jul 7, 2007 | 05:39 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The pin becoming loose in the casting it one source for the floppy sunvisor. You could also have a broken or missing plastic sleeve. The sleeve is tightened by the screw to provide tension to the pin and prevent movement. If your pin doesn't rotate in the casting, then the sleeve could be the problem. I've had both problems causing the symptom.
Lon
Old Jul 7, 2007 | 06:06 PM
Cadillac's Avatar
JamesC
Yeah. I don't have one of those.
Old Jul 8, 2007 | 05:40 AM
JamesC's Avatar
Here's a link to the sleeve that Lon mentioned:
http://www.top-downsolutions.com/pro...roducts_id=155
JamesC
Old Sep 1, 2007 | 10:13 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Thanks ...that is the help I was looking for...
Old Sep 1, 2007 | 11:16 AM
JamesC's Avatar
Always here for you, 86 .
JamesC
Old Sep 1, 2007 | 03:15 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
I had the same problem with my visors falling down all the time and found a very simple solution. Just push the visor about 2 inches towards the windshield until it feels tight then theres enough pressure on it so it doesnt fall down. Ive had mine liek that for about 2 years and they dont come down going over trian tracks speed bumps etc.
Old Nov 10, 2007 | 05:54 AM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
I tried that and it worked for about a day or two...So i just went out and bought some JB Weld and fixed the rotating bullet and also ordered a new pair of plastics inserts from TDS (mine were a lil worn) Good as new!
Old Jul 13, 2011 | 07:54 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
(Old thread Revival)
The first thing I did was go back to my parts cars... Then I discovered there was two styles, I later found out that the Hard Top and T-top/convertible types are different. One had the same problem, so that was no good, and another was corroded, so I really did not want to use that one either...
Ultimately I used superglue, the real thin runny stuff... stood the arm on end, and then let it run in... Works like a charm.. And it is invisible, I cannot even tell I did it.
I have also been told that you can sometimes tap them in with a hammer, there is some knurling on them so it works about 50% of the time (Thanks Drew)
John
Old Jul 13, 2011 | 07:56 AM
okfoz's Avatar
This topic (if not already in existence) might make a nice mini tech article.
Old Jul 14, 2011 | 08:13 PM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
Has anyone out there tried transplanting the visors from another car? The visors on my Firebird were both as limp as a piece of cooked spaghetti when I bought it, so I took them off. I'm pretty tall, and it wasn't a problem to me, but my son complains about not having a visor on his side.
I already disassembled my old visors, and the "bullet" mentioned above turns freely and can't be fixed with inserts.
I'd try the JB-weld/superglue trick, but I always thought that the visors on these cars were pretty pathetic to begin with; they don't even come close to covering all of the top area. Also, I would like something with a built-in mirror.
Does anyone out there have any suggestions?
Old Jul 14, 2011 | 10:26 PM
okfoz's Avatar
I think doing what you are proposing would be easier on a coupe than a T-top car. The T-top cars have a contoured sun-visor that I think are unique to the F-body. The coupe on the other hand are mor like your typical sunvisor that I think you could simply find another car and install them
GM used to be a company that used tons of similar parts from car to car... Outside Door Handles for example were used on dozens and dozens of different model cars, with minor variations. The Steering columns pieces and parts were all the same in the 80's. I would think if you went to a junkyard and found something with a similar screw pattern you could probably install it. Some of the integrated mirror sunvisors I have seen lately have a support toward the center of the car, I think if you got something with an integrated mirror it may sag some...
I do not know, just a thought... The only thing you can do is go scour the yards for a set and see what you can do with them.
John
Old May 13, 2013 | 06:37 PM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
(REVIVAL)
I took my floppy visors apart, chucked them up in the vise with the aforementioned "bullet" pointing straight up and dribbled RED loctite around the base of the bullet while spinning it until all the bubbles came out and I couldn't add anymore loctite, (about 2 minutes for each side) Let them sit overnight and re assembled -- worked like brand new -- now we get to see just how long they last.....
1992 Trans Am
May 10, 2023 07:19 PM
PurelyPMD
May 5, 2016 04:57 PM
1MeanZ
Dec 18, 2015 05:39 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
andy74
Sep 3, 2015 08:41 AM
