Led gauge questions
Old Feb 6, 2010 | 01:58 PM
topher1316's Avatar
Led gauge questions
Hey guys I'm witching out the 194 bulbs with red leds(5 points). I have the cluster off and there are 17 bulbs, which ones do I replace. And I want to replace the green turn signals with purple(pretty sick I know). Now I was thinking I could take out that green translucent disc and just put in a purple led. The only ones i could find were UV/blacklight ones, is that purple or not?
And I wanted to paint the metal part of the gauge behind the clear plastic a metallic silver paint. what you guys think>
Old Feb 6, 2010 | 02:42 PM
CamaroDude90's Avatar
Car: 1989 Camaro RS
Engine: 2.8l V6
Re: Led gauge questions
You should . There are alot of threads like this here.
https://www.thirdgen.org/leddash
The UV/blacklight ones are purple but I think they are not so bright.
I changed all 11 bulbs to blue LEDs but it was quite dim. Painted the back of the metal thing white and it's perfect for me now. I was thinking of the turn signal bulbs too but I thought they wouldn't work cause the LEDs use so low power. Someone correct me if I'm wrong.
Old Feb 6, 2010 | 02:58 PM
topher1316's Avatar
Thanks for the link, I basically got all that, but instead I am using 194 mini wedges(5 leds in one), they are a direct fit. I am confused about what to paint white(in my case silver). In that link he says he painted the back of the front piece, but then you said the metal piece( I'm assuming the metal piece that is black in the front and blue in the back???
Chris
Old Feb 6, 2010 | 03:05 PM
Car: 1989 Camaro RS
Engine: 2.8l V6
I used 194 mini wedges too, they had 1 diode per bulb though.
Yes, the metal thing that is black in front and blue in the back.
Old Feb 6, 2010 | 06:15 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Chris
Yes, that black piece. Here's the one I painted red to match the car. The back side was painted silver, but I've since painted it flat white.
Old Feb 6, 2010 | 09:07 PM
topher1316's Avatar
Would you say the white works better than a metallic silver would?
Old Feb 6, 2010 | 09:34 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
i did mine white when i put all white leds in to get rid of the "blue effect." worked great for me.
didnt think to try silver, too me white just seemed the best option.
Old Feb 6, 2010 | 10:41 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
The only difference i think there would be with a chrome/metallic color would be the arrays of light shining vs white is more of a flood light type, such as metallic too but like i said it'll give arrays.
Old Feb 7, 2010 | 12:44 AM
topher1316's Avatar
By arrays are you basically saying it wouldn't look even?
Old Feb 7, 2010 | 07:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's what I did back in 2002 (so long ago I had to go looking for it):
https://www.thirdgen.org/forums/body...r-cluster.html
BTW, even with high intensity 194's, the difference from OE was considerable. As a side note, I can't believe how much the interior of my car has changed since those pics were taken. A newer pic in my Car Details below.
JamesC
Old Feb 7, 2010 | 10:06 AM
Hammer's Bird's Avatar
Car: 1984 Pontiac Trans Am
Engine: 305 in car 350 Vortec soon
Transmission: Automatic
Hey guys,
I did something similar with my 84 TA and I wanted to paint the back of my gauges white because as of now they are orange and they reflecting my blue LED's and making a mixed orange-blue. but my problem is i could not get the metal part of the gauge off on the speedometer so being my young impatient self i thought the needle came of by pushing in and sliding. Well i really should have asked on of you first because i basically sheered the needle off at the connection so does anyone have any solutions like a fix for that or a new speedometer anything would be much appreciated!!
Old Feb 7, 2010 | 09:49 PM
topher1316's Avatar
JamesC, What kind of paint did you use for the silver. Was it a metallic rattle can, or actual automotive paint, thanks
Old Feb 8, 2010 | 06:11 AM
JamesC's Avatar
Met. rattle can.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
fonzie85
Aug 13, 2015 11:50 AM
