Aeroforce Gauges...anybody using them & what do you think of them?
Old Feb 10, 2010 | 11:14 PM
NVRENUF's Avatar
I am thinking of getting 1 or 2 Aeroforce gauges... http://www.aeroforcetech.com/index.html
Just wondering if anybody is using them & what they think. They are for newer OBD2 cars. Mine is an '89 IROC and I am currently having A 421c.i. small block built.Going to up the boost to 15 psi as well.I am also changing the computer system to a 2001-2002 LS1 system from http://www.eficonnection.com/eficonnection/default.aspx This will allow me to use these gauges.If someone is using them,do you feel 1 gauge is enough as it will display 2 parameter's at once or would running 2 be better? They are expensive so I want to be sure they're worth it.
Old Feb 22, 2010 | 03:36 AM
Transmetal's Avatar
Car: 89 Trans Am GTA
Engine: 5.7 350 TPI L98
Axle/Gears: Borg-Warner 3.27
Re: Aeroforce Gauges...anybody using them & what do you think of them?
I was wondering kinda the same thing. I wanted to install an AeroForce scan gauge but I don't think it's compatible with the 89 gta.
Old Feb 22, 2010 | 08:20 PM
NVRENUF's Avatar
They are compatible with OBD2 cars only.They plug into the ALDL connector. I am changing my whole computer system to an LS1/2 setup from EFI connection. That's why I can now use them.
Old Feb 23, 2010 | 09:11 AM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
I had one in my 98 formula. I really liked it.
Old Feb 24, 2010 | 06:40 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
If you can make it work with the PCM set up you are going to use then they are great. I love mine... I have the older style and the newer ones are MUCH nicer. The only reason I didnt upgrade to the newer model is when mine turns on the pontiac arrow displays on the screen for a few seconds...which was a major selling point for me.
J.
Z28FAST1
Southern California Area
Jul 10, 2014 02:47 AM
L98-IROC
Jun 19, 2014 06:47 AM
ghettocruiser
Dec 29, 2013 11:44 AM
Mitsumark
Firebirds Wanted
Oct 16, 2007 11:51 AM
