STEERING COLUMN HELP
Old Feb 12, 2010 | 08:42 PM
pgmonster's Avatar
Car: Firebird Pro/Am
Engine: 5.0 TBI
I recently busted the plug in thing at the bottom of the steering column on my 89' firebird and i figured i would just go to a junkyard and get a whole new column but all the ones near me dont have any third gen cars and i was wondering if i could get the column out of any other car/truck cause they have an S10 and a monte carlo with columns that look alot alike so if anyone has put one in with success or know the column part number for mine it would be a world of help THANKS
Old Feb 12, 2010 | 08:59 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Re: STEERING COLUMN HELP
Well, here's the bad news. 1989 was a one year only column so in order for everything to work correctly you need a column from an '89 Camaro or Firebird. The only difference between '84-'88 columns and an '89 column is the addition of the VATS system. So if you want to bypass the VATS system you can use a column from an '84-'88 car. The '90-'92 columns used VATS as well but the wiring is completely different.
Of course, you could also get an '84-'88 column and swap over the lock cylinder from you old column which would keep your VATS functional.
Old Feb 12, 2010 | 09:08 PM
pgmonster's Avatar
Engine: 5.0 TBI
well i've already bypassed the VATS (the guy i bought it from lost the key) so thats no problem and that the only difference? and i just found out that the junkyard has a 91 but that wont work at all is what your saying? and do you know of any other car i could get one out of that uses the same column?
Old Feb 12, 2010 | 09:21 PM
Former Sponsor
Car: Too many
Yes, as long as you bypassed your VATS system you can use one from an '84-'89 car. The wiring is different on other years.
Old Feb 12, 2010 | 09:34 PM
pgmonster's Avatar
Engine: 5.0 TBI
i just found an 87 camaro at a junkyard will that work in my firebird?
Old Feb 12, 2010 | 09:39 PM
Former Sponsor
Car: Too many
Yep, it will work.
Old Feb 12, 2010 | 09:49 PM
pgmonster's Avatar
Engine: 5.0 TBI
ok thanks alot
Old Feb 14, 2010 | 06:38 PM
pgmonster's Avatar
Engine: 5.0 TBI
so i went to the junkyard today turns out the camaro had a 5spd and i remeber reading somewhere that it wont work is that true thanks i could really use the help!!
Old Feb 14, 2010 | 11:42 PM
Former Sponsor
Car: Too many
It will work but you'll need to add a piece from your old column. Just put the two column side by side and you'll see the piece missing on the 5-speed column. All you need to do is take it off your old column and add it to the new one.
Old Feb 17, 2010 | 05:39 PM
pgmonster's Avatar
Engine: 5.0 TBI
alright thanks
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
