87 Z28 cluster
Old Feb 15, 2010 | 09:25 AM
Trapshot's Avatar
Engine: 305 carb
87 Z28 cluster
I have a 87 Z28 with 85 mph Cluster, can I swap it out with a 140 mph one. speedo is bouncing around all over, cable is good and gear in tail piece is fine
Old Feb 15, 2010 | 09:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 87 Z28 cluster
Welcome to TGO. A search is always good advice on the boards, as some questions have been asked many times.
I'd suggest that you swap in the 145 speedo head instead of the entire cluster to avoid any possible electrical gremlins. The swap is direct. Since the odometer has probably taken a dump, the following link provides a fix:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
It's possible that you speedo has gone south, but you might take a look at possible problems:
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
Old Feb 15, 2010 | 10:05 AM
Trapshot's Avatar
Engine: 305 carb
Re: 87 Z28 cluster
Thanks James
As soon as I find the 145 I'll pull it out and let you know how I made out
Ed
Old Feb 15, 2010 | 10:12 AM
Trapshot's Avatar
Engine: 305 carb
Re: 87 Z28 cluster
Thanks James
As soon as I find a 145 one I'll Pull it and let you know how I made out.
Ed
codeysabatini
Sep 20, 2015 11:36 AM
Trevor Tarry
Sep 15, 2015 02:04 AM
TrevinE
Sep 14, 2015 03:20 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
90formulaVortec
Sep 8, 2015 12:42 AM
