4thgen dash, need the bad pictures. Yes, I've searched
Old Feb 28, 2010 | 01:15 PM
Ethan91's Avatar
Car: 1991 Camaro Z28
Engine: 6.2L LS3 to come
Transmission: 4L60E LVL2 700rwhp
For everyone that has done the 4thgen dash swap, I want to see the things that you aren't happy with. I hear there are a couple gaps and what not. I'm thinking about doing a swap, but I want to be sure it will look good.
Old Feb 28, 2010 | 05:05 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Re: 4thgen dash, need the bad pictures. Yes, I've searched
Well the main area's are the A/B pillars on the sides of the dash. I found the B pillar to be easily modded in. The A piller can be done and looks ok from the inside but definatly not up to factory quality at all. The fit and finish will be poor without some glassing of those items.
Old Feb 28, 2010 | 06:00 PM
Ethan91's Avatar
I'm trying to see my options. It seems most people aren't happy with the finished result.
Also does anyone know if a 3rdgen or 4thgen dash will fit into a 1st generation camaro? If so I'm thinging about putting the 04-06 GTO dash in my camaro, because I know that dash fits in the 1st gens.
Old Feb 28, 2010 | 06:10 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
I have seen 4thgen dashes in 2ndgens but im not sure how the 1st and 2ndgen compatibility goes as far as the dash goes. Anything can be put in pretty easy its only a matter of making it functional and stock looking after it's in.
Old Feb 28, 2010 | 06:12 PM
Ethan91's Avatar
Here's a picture of one I found
Attached Thumbnails 4thgen dash, need the bad pictures. Yes, I've searched-27994290971.jpg
Old Feb 28, 2010 | 06:20 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
There is a member on here who has that dash but from the Austrailian version mounted in his thirdgen. Do a search he had some pics up.
Old Feb 28, 2010 | 06:35 PM
Ethan91's Avatar
I found it , title wasnt a give away. Thanks man
https://www.thirdgen.org/forums/inte...sion-85-a.html
Ghettobird52
Jul 5, 2024 11:18 PM
Jorlain
Aug 24, 2022 05:11 PM
NORTz89
May 20, 2020 03:51 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
Jk_Under
Sep 2, 2015 10:59 PM
