What Am I Doing Wrong (auto shifter removal)
Old Mar 2, 2010 | 01:16 PM
cjames9001's Avatar
Car: 1986 Trans Am WS6 Pkg.
Ok so I've located that U shaped clip that holds my shifter in place but I cant for the life of me get it out, I tried snap ring pliers, regular pliers, and I attempted to jam a screwdriver in there to wedge it out, none of this worked, I was wondering if someone else has done something else to get it out... I'm thinking its just really worked in there tight anyone have any ideas?
Old Mar 2, 2010 | 03:17 PM
LTL_DMON's Avatar
Car: 1986 Trans AM
Re: What Am I Doing Wrong (auto shifter removal)
Have you tried moving the shifter around to help loosen up the clip while you try to pull it out... maybe a small bit of WD40 could help too... also, shifting it into 1st will make it easier to get to.
Old Mar 2, 2010 | 05:03 PM
cjames9001's Avatar
well I moved it into first, I'll try wiggling it but if i remember from earlier I couldn't get it to even move the slightest bit, and I'll try the WD-40 thanks... I'll post if I get it off
Old Mar 2, 2010 | 05:21 PM
jj74sd455's Avatar
Car: 91 bird
Engine: 305 tbi
Transmission: 4 speed automatic
Axle/Gears: factory
when i removed mine it was in there too,patience grasshopper
Old Mar 2, 2010 | 06:59 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Just a flat head screwdriver, and pry it out. Works for me everytime.
Old Mar 2, 2010 | 08:52 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
i always use a 90* angle sharpened pick to get it out
Old Mar 2, 2010 | 09:36 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
Use a thin screw driver to carefully get under the clip, and when it's out a little, grab it with a small pair of pliers and pull it out.
Old Mar 4, 2010 | 05:51 PM
cjames9001's Avatar
ok well I got it out, after a 90* angled pick, a small screw driver, and snap ring pliers failed me I found a painters tool for opening paint cans and beer on the other side lol; it got it out first try, I also sprayed some losener stuff in there, cant remember what it was called but it smelled like oranges lol anyways I put a picture up so you can see and if anyone else runs into the problem of it being really stuck in there maybe this'll help.. thanks to everyone that suggested different things, dunno where I'd be without this board!
Attached Thumbnails What Am I Doing Wrong (auto shifter removal)-dsc00603.jpg   What Am I Doing Wrong (auto shifter removal)-dsc00604.jpg   What Am I Doing Wrong (auto shifter removal)-dsc00605.jpg
Old Mar 5, 2010 | 02:22 AM
webeeZ28's Avatar
Car: 1992 Z28 L98 G92
Engine: 5.7 350 B2L
Transmission: 700 R4
Congratulations
BewleyBizzIROC
Feb 3, 2020 09:52 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
NBrehm
Aug 25, 2015 11:49 PM
3rdgenparts
Aug 8, 2015 07:09 PM
Leggman1
Aug 6, 2015 04:15 AM
