door panel rebuild questions
Old Mar 6, 2010 | 08:25 AM
hinton38's Avatar
Car: 1987 Black Iroc Camaro
Engine: 5.7l TPI
Transmission: a4 automatic
Axle/Gears: borg warner9 bolt 3:.27
i bought a 87 iroc and the door panels were trashed from years of leaky t-tops and the backing when i took if of just disintegrated and there was mold all over the back part the fabric is in really awesome shape can you buy backing board for the cars and redo it your self and or just take it to a professional and have them do it whats you r guys opinions or do you all have any suggestions for me thanks
Old Mar 6, 2010 | 08:31 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: door panel rebuild questions
You can do it yourself, but you'll need something for a template. The board itself you can get at Home Depot(probably Lowes too). At the one near me at least, its with the plywood and goes by a bunch of different names, Hardboard, Hardi-board, etc. Its smooth on one side and has a pretty rough texture on the backside.
Old Mar 6, 2010 | 08:33 AM
hinton38's Avatar
Engine: 5.7l TPI
thanks man my only question are the thickness the same
Old Mar 6, 2010 | 08:42 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Should be. My Home Depot has it in a couple thicknesses. I would think 1/4" should work just fine.
Old Mar 6, 2010 | 08:46 AM
hinton38's Avatar
Engine: 5.7l TPI
the only thing is at the top there are like 6 ribbed diagonal lines going down into the arm rest how did you copy that
Old Mar 6, 2010 | 10:09 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Actually, I haven't done it yet. Its on the list of things to do when I get around to the interior. To answer your question about the bars, my car doesn't have those. My factory panels are just flat with carpeting on them.
Old Mar 6, 2010 | 10:13 AM
hinton38's Avatar
Engine: 5.7l TPI
yeah i thought mine were too but when i took the cloth part off those ribs were there and then i saw the thread on hear about the ribs and on my car there supposed to be there
Old Mar 6, 2010 | 12:12 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
I believe they were an IROC/Z28 only thing. I remember a friend of mine had an 85 IROC and an 89 RS and only the 85 had the bars on the door panel. I haven't really paid much attention to it really as I'm not a fan of them, but at the same time my door panels look too plain without them.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
